Home » Eclipse Projects » GEF » Funny tab characters in Draw2d
Funny tab characters in Draw2d [message #68389] Wed, 05 March 2003 08:20 Go to next message
Originally posted by: lking.tsti.co.za
Hi All
I am having a problem with the text in Draw2d. I've created a function
that will read a block of text from a file line by line and place this
text within a TextFlow object. This function then places this in a
BlockFlow and returns this.
The function seems to work as it does show the text BUT the tab character
is shown as some weird symbol. If instead of placing this in the textflow
and just use printline it works fine.
Heres the code:
protected IFigure createCode() {
BlockFlow blockFlow = new BlockFlow();
TextFlow contents = new TextFlow();
//contents.setFont(ITALICS);
String fileHeader;
try {
ResultSet result =
stmt.executeQuery(
"SELECT * FROM [Lambdas] WHERE lambda_id = '" + id + "'");
result.next();
fileHeader = result.getString("code_block");
if(fileHeader != null){
StringTokenizer stok = new StringTokenizer(fileHeader);
String file = stok.nextToken();
String begin = stok.nextToken();
String end = stok.nextToken();
FileReader in = new FileReader(file);
BufferedReader breader = new BufferedReader(in);
// skip unnecessary beggining lines
for (int i = 0; i < Integer.parseInt(begin.trim()); i++) {
breader.readLine();
for (int i = 0; i <= Integer.parseInt(end.trim()) -
//String temp = new String(breader.readLine());
//temp = temp+"\n";
//contents.setLayoutManager(new SimpleTextLayout(contents));
contents = new TextFlow(breader.readLine() + "\n");
//contents.setText(temp+"\n");
blockFlow.add(contents);
else{
contents.setText("No code available.");
} catch (Exception e) {
System.out.println("Error: CodeDialog.createCode");
return blockFlow;
Re: Funny tab characters in Draw2d [message #68396 is a reply to message #68389] Wed, 05 March 2003 08:30 Go to previous messageGo to next message
zapod7 wrote:
Sorry heres a more formatted copy of the code:
String file = "somefile";
// read until reach end which is some int
for(int i = 0; i <= end; i++) {
in.close();
breader.clos();
return blockFlow;
Re: Funny tab characters in Draw2d [message #68417 is a reply to message #68389] Wed, 05 March 2003 10:12 Go to previous messageGo to next message
Tabs are not currently supported in the text package.
We are simply using GC.drawString() and stringExtent() to wrap the text, so
tabs are treated as unknown characters in these methods. We would have to
add "tab stop" support to flow context in order to process tabs correctly.
"zapod7" <lking@tsti.co.za> wrote in message
news:b44tjp$n0k$1@rogue.oti.com...
> Hi All
> Heres the code:
> String fileHeader;
> try {
> ResultSet result =
> stmt.executeQuery(
> result.next();
> breader.readLine();
> //temp = temp+"\n";
> else{
> return blockFlow;
Re: Funny tab characters in Draw2d [message #68461 is a reply to message #68417] Thu, 06 March 2003 01:23 Go to previous message
Will you be adding this feature and if so do you know when this will
happen?
Len
> add \"tab stop\" support to flow context in order to process tabs correctly.
> \"zapod7\" <lking@tsti.co.za> wrote in message
> > Hi All
> > I am having a problem with the text in Draw2d. I\'ve created a function
> > Heres the code:
> > String fileHeader;
> > try {
> > ResultSet result =
> > stmt.executeQuery(
> > \"SELECT * FROM [Lambdas] WHERE lambda_id = \'\" + id + \"\'\");
> > result.next();
> > fileHeader = result.getString(\"code_block\");
> > breader.readLine();
> > //temp = temp+\"\\n\";
> > contents = new TextFlow(breader.readLine() + \"\\n\");
> > //contents.setText(temp+\"\\n\");
> > else{
> > contents.setText(\"No code available.\");
> > System.out.println(\"Error: CodeDialog.createCode\");
> > return blockFlow;
Previous Topic:connection routers, etc.
Next Topic:Problem with italic Text in Draw2D
Current Time: Sat Aug 30 14:32:50 EDT 2025
Powered by FUDForum. Page generated in 0.06210 seconds
