Home » Eclipse Projects » SWTBot » IllegalArgumentExceptions in logging for simple test case
IllegalArgumentExceptions in logging for simple test case [message #6068] Wed, 03 December 2008 12:27 Go to next message
Now that I have a logging xml file in place, I am noticing some
IllegalArgumentExceptions reported in the Eclipse Console for a simple
test case derived from SWTEclipseBotTestCase.
The test case class:
public class DummySWTBotTestCase extends SWTBotEclipseTestCase{
public void setUp()
System.out.println("setting up test case");
public void tearDown()
System.out.println("tearing down test case");
public void testDummy1() throws Exception
System.out.println("#Testing# running testDummy1()");
bot.view("Navigator").show();
I only debugged the first such exception. The call stack for which is
attached. At net.sf.swtbot.utils.MessageFormat.toString(), the last
entry before getting into Java API code, the values for the arguments are.
s = "method {0} {{1}}, using matcher: {2}
args[0] = "ViewReference"
args[1] = ""
args[2] = ""
Has anyone else ran into anything similar with the logging for SWTBot or
have any suggestions for correcting this?
Joe
Re: IllegalArgumentExceptions in logging for simple test case [message #6113 is a reply to message #6068] Wed, 03 December 2008 12:57 Go to previous messageGo to next message
> args[1] = ""
> args[2] = ""
This was fixed as part of http://swtbot.org/bugzilla/show_bug.cgi?id=131
You could checkout revision 1128 from SVN in case you'd want to fix this
yourself, or modify the source as per the description in the bug
(basically remove the double brace {{1}} to make it {1})
-- Ketan
Re: IllegalArgumentExceptions in logging for simple test case [message #6129 is a reply to message #6113] Wed, 03 December 2008 14:55 Go to previous messageGo to next message
>> are.
>> args[1] = ""
>> args[2] = ""
> -- Ketan
Thanks for the information Ketan. It looks like the defect is marked as
targeted for the 2.0.0 release. I am using the latest version of the
SWTBot jars that I could find, 2.0.0.1115-dev. Is there a nightly build
going to happen any time soon that will incorporate the fix for this defect?
Joe
Re: IllegalArgumentExceptions in logging for simple test case [message #6142 is a reply to message #6129] Wed, 03 December 2008 22:53 Go to previous messageGo to next message
> defect?
I've pushed out revision 1164[1] which is the last nightly that'll be
available on sf.net. Revisions after that have undergone major changes
in terms of renaming all things net.sf.swtbot to org.eclipse.swtbot.
Enjoy!
[1] http://swtbot.sourceforge.net/artifacts/2.0-dev/
-- Ketan
Re: IllegalArgumentExceptions in logging for simple test case [message #6155 is a reply to message #6142] Thu, 04 December 2008 17:21 Go to previous message
>> defect?
> Enjoy!
> -- Ketan
Thanks Ketan. I just installed that build and verified that the issue is
fixed in it.
Joe
Previous Topic:Other SWT functional testing tools
Next Topic:documentation of swtbot 2.0
Current Time: Fri Nov 28 12:12:58 EST 2025
Powered by FUDForum. Page generated in 0.04312 seconds
