Home » Eclipse Projects » Mylyn » Creating Mylyn task from // TODO: comment marker via QuickFix
Creating Mylyn task from // TODO: comment marker via QuickFix [message #68167] Sun, 19 April 2009 13:25 Go to next message
Hi!
It seems to me that there is no easy way to create Mylyn task from marker
in comment, so here is a short user story:
One sees
// FIXME: foo bar baz
in their code.
They put cursor on that line, press CTRL+1 (or right-click on the task
mark in the margin), and select "Create Task" in quick qix popup.
Task editor opens with task summary set to "foo bar baz".
Krzysiek Goj
Re: Creating Mylyn task from // TODO: comment marker via QuickFix [message #68181 is a reply to message #68167] Mon, 20 April 2009 04:11 Go to previous messageGo to next message
> marker in comment
You can use Tasks or Markers views. Right-click on a marker and select
"New Task from Marker...".
> One sees
> in their code.
Creating tasks this way could also be useful.
Radoslaw Jozwik
Re: Creating Mylyn task from // TODO: comment marker via QuickFix [message #68261 is a reply to message #68167] Fri, 24 April 2009 16:53 Go to previous message
Krzysiek Goj wrote:
> Hi!
> marker in comment, so here is a short user story:
> One sees
> in their code.
> Best regards,
Can you open a bug at http://bugs.eclipse.org/bugs with this request, it
doesn't seem to hard to implement as the action is already there for teh
Tasks view.
Maarten
Re: Creating Mylyn task from // TODO: comment marker via QuickFix [message #597467 is a reply to message #68167] Mon, 20 April 2009 04:11 Go to previous message
> marker in comment
> One sees
> in their code.
Radoslaw Jozwik
Re: Creating Mylyn task from // TODO: comment marker via QuickFix [message #597514 is a reply to message #68167] Fri, 24 April 2009 16:53 Go to previous message
Krzysiek Goj wrote:
> Hi!
> One sees
> in their code.
> Best regards,
Tasks view.
Maarten
Previous Topic:Mylyn 3.1.1 is now available
Next Topic:Mylyn/Trac Authentication Failing...
Current Time: Thu Jun 19 18:26:06 EDT 2025
Powered by FUDForum. Page generated in 0.09095 seconds
