Home » Eclipse Projects » Eclipse Platform » Error trying to use external jar
Error trying to use external jar [message #68119] Mon, 09 June 2003 12:33 Go to next message
Originally posted by: rdovich.alterpoint.com
I need to read an xml file into a DOM. I tried Xerces but I get I get a
java.lang.NoClassDefFoundError looking for
org/apache/xerces/parsers/AbstractDOMParser at runtime.
I then tried Crimson and get basically the same thing
(java.lang.NoClassDefFoundError: javax/xml/parsers/DocumentBuilderFactory).
What am I doing wrong? I simply added the jar to the Java Build Path in the
Libraries tab.
Ron
Re: Error trying to use external jar [message #68201 is a reply to message #68119] Mon, 09 June 2003 13:13 Go to previous messageGo to next message
> Libraries tab.
> Ron
Ron :
Are you trying it in a plugin or in a standalone app ? If you are
running in a standalone app, try to add xercesImpl.jar to the build
classpath. If you are trying to read in a plugin, you need to add
org.apache.xerces_4.0.7 to your plugin dependencies.
Sincerely,
Antonio
Re: Error trying to use external jar [message #68225 is a reply to message #68201] Mon, 09 June 2003 13:32 Go to previous message
Thanks Antonio! I forgot about the entry required in plugin.xml.
Thanks again for jarring my memory!
Ron
"Antonio Edson Ceccon" <cecconae@ig.com.br> wrote in message
news:bc2f7l$lnl$1@rogue.oti.com...
the
> > Libraries tab.
> > Thanks,
> > Ron
> Ron :
> Sincerely,
> Antonio
Previous Topic:[ANN] "The Developer's Guide to Eclipse" now shipping
Next Topic:can't find 'swt.jar' (Eclipse linux)
Current Time: Thu Oct 16 11:05:41 EDT 2025
Powered by FUDForum. Page generated in 0.04420 seconds
