Home » Archived » XML Schema Definition (XSD) » getFacets() Vs getFacetContents()
getFacets() Vs getFacetContents() [message #68109] Thu, 11 May 2006 01:57 Go to next message
Originally posted by: gilado74.gmail.com
HI,
What is the difference between getFacets() and getFacetContents()?
In what cases i would like to use the getFacets()function instet of
getFacetContents() and vice versa ?
As i notice, for the following XSD
the getFacetContents() returns only the "XSDPatternFacetImpl"
while the the getFacets() return "XSDPatternFacetImpl" and
"XSDWhiteSpaceFacetImpl"
<xs:simpleType name="myPatern">
<xs:restriction base="xs:string">
<xs:pattern value="[A-Z]{6,6}[A-Z2-9][A-NP-Z0-9]([A-Z0-9]{3,3}){0,1}"/ >
</xs:restriction>
</xs:simpleType>
Gili
Re: getFacets() Vs getFacetContents() [message #68123 is a reply to message #68109] Thu, 11 May 2006 06:03 Go to previous messageGo to next message
Gili,
The first one will return all facets that are in effect based on
inheritance while the second one will return those facets physically
present in the given type. You'd use the former if you want to know all
the constraints that apply, and the later if you want to understand
where in the hierarchy the constraints are being specified and for
editing those constraints; since the first one is computed from the
second one, only the second one can be edited directly.
Gili wrote:
> HI,
> As i notice, for the following XSD the getFacetContents() returns only
> the "XSDPatternFacetImpl" while the the getFacets() return
> "XSDPatternFacetImpl" and "XSDWhiteSpaceFacetImpl"
> <xs:pattern
> </xs:restriction>
> </xs:simpleType>
> Gili
Re: getFacets() Vs getFacetContents() [message #68136 is a reply to message #68123] Thu, 11 May 2006 09:39 Go to previous message
Ed,
Thanks for the clarification.
Re: getFacets() Vs getFacetContents() [message #598081 is a reply to message #68109] Thu, 11 May 2006 06:03 Go to previous message
Gili,
Gili wrote:
> HI,
> <xs:pattern
> </xs:restriction>
> </xs:simpleType>
> Gili
Re: getFacets() Vs getFacetContents() [message #598087 is a reply to message #68123] Thu, 11 May 2006 09:39 Go to previous message
Ed,
Previous Topic:getFacets() Vs getFacetContents()
Next Topic:One element -> multiple types ?
Current Time: Thu Jul 24 03:43:28 EDT 2025
Powered by FUDForum. Page generated in 0.05456 seconds
