[ATL] ATL Warning [message #6025] |
Mon, 08 January 2007 15:10  |
Originally posted by: irbull.cs.uvic.ca
I get the following warning each time I run an ATL transformation:
WARNING: overwriting local EMF registry entry for org.viewshaper
Is this a problem?
Ian
Re: [ATL] ATL Warning [message #6067 is a reply to message #6052] |
Mon, 08 January 2007 18:48   |
Originally posted by: mikael.barbero.gmail.com
Hi Ian,
More precisely, it is a debug information that will certainly be removed
in the next ATL release (i.e., when ATL will be released as M2M component).
Mikaël
Freddy Allilaire a écrit :
> Hi Ian,
> No, it is not a problem.
> Freddy.
>> Is this a problem?
>> Cheers,
>> Ian
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] ATL Warning [message #15326 is a reply to message #6067] |
Tue, 06 February 2007 07:08  |
Mikaël Barbero schreef:
> Hi Ian,
It is indeed debug information that I added. It was meant to track down
memory leak issues with loading EMF-based models. However, this WARNING
still means just that: something really is wrong. It just doesn't
necessarily result in real errors.
For example, the following appears on the console during ATL startup:
ATL Console initiated
WARNING: overwriting local EMF registry entry for PrimitiveTypes
WARNING: overwriting local EMF registry entry for AM3
It means that the PrimitiveTypes and AM3 meta-models are registered
multiple times. This should not happen, but doesn't create any further
problems. The same model is just registered more than once.
Now consider running your own model transformation, with your own
PrimitiveTypes model. If you now get this warning, you will know that
any pre-loaded PrimitiveTypes model needed internally by ATL has now
been replaced by your own model. THAT may well cause havoc!
When considering all this, it seems a good idea to retain the warning
message:
- save time tracking down instances of the second issue.
- track down (non-fatal) bugs in ATL (and other AMMA components) and "do
the right thing": solve the cause, not the symptom.
Dennis
> Best regards,
> Mikaël
>> Hi Ian,
>> Regards,
>> Freddy.
>>> Is this a problem?
>>> Cheers,
>>> Ian
FUDForum. Page generated in 0.04327 seconds
