Home » Eclipse Projects » GEF » layer/paint problem with connections/nodes
layer/paint problem with connections/nodes [message #67592] Fri, 28 February 2003 15:20 Go to next message
Originally posted by: jwoods.journee.com
I just recently updated to I20030255 (previously running with I20030121). I
now notice a problem that didn't appear to be there before. The problem is
that my connections are being painted on top of my nodes (nodes not
associated with the connection - see attached image). Is this a bug or new
behavior? If new, is there a way to switch back to the previous behavior
where nodes are always painted on top of connections?
- Jason
Re: layer/paint problem with connections/nodes [message #67613 is a reply to message #67592] Fri, 28 February 2003 15:49 Go to previous messageGo to next message
This is old behavior (really old). Are you sure you didn't see this on the
other build?
"Jason Woods" <jwoods@journee.com> wrote in message
news:b3ogo9$upp$1@rogue.oti.com...
I
is
new
> - Jason
Re: layer/paint problem with connections/nodes [message #67634 is a reply to message #67592] Fri, 28 February 2003 15:50 Go to previous messageGo to next message
It is also as designed, but applications can override the deafult behavior.
I
is
new
> - Jason
Re: layer/paint problem with connections/nodes [message #67653 is a reply to message #67592] Fri, 28 February 2003 15:58 Go to previous message
Actually I just tried an older build and verified the behavior was the same.
How can I switch the paint/visibility order of the layers so that
connections are "below" nodes?
- Jason
I
is
new
> - Jason
Previous Topic:problem with Polyline decorations
Next Topic:ETA for zoom actions?
Current Time: Sat Aug 30 12:56:57 EDT 2025
Powered by FUDForum. Page generated in 0.03905 seconds
