Home » Archived » BIRT » Setting field separators for flat files
Setting field separators for flat files [message #67476] Thu, 11 August 2005 14:50 Go to next message
Originally posted by: frank.backes.centif.de
Is it somehow possible to set user-specific field separators for flat file
datasources? The flat files I have received from my customer use
semicolons rather than commas.
Re: Setting field separators for flat files [message #84076 is a reply to message #67476] Wed, 26 October 2005 05:42 Go to previous messageGo to next message
Hi Frank,
have you solved your problem?
I have the same problem: can you tell me the solution?
Pietro.
> file datasources? The flat files I have received from my customer use
Re: Setting field separators for flat files [message #1708373 is a reply to message #84076] Wed, 16 September 2015 00:28 Go to previous message
I am new to BIRT and facing same issue. My input file has field separator as semicolon.
When I add the file as datasource, and create a new datacase, it doesnt show me columns.
Do you have find solution for the same ?
Previous Topic:How to fix position of Export icon in Eclipse view
Next Topic:Creating Multi Sheets Report in BIRT
Current Time: Mon Jul 21 21:58:58 EDT 2025
Powered by FUDForum. Page generated in 0.25355 seconds
