Home » Eclipse Projects » Remote Application Platform (RAP) » Link support
Link support [message #5999] Tue, 13 March 2007 15:10 Go to next message
I would like to create a Link in my Application to a different website.
Now I am searching for something like <a href="someURL" target="_blank">
in html. In an SWT based Appication I use
PlatformUI.getWorkbench().getBrowserSupport() to create a new Brwoser
Windos, but I didn't find the BrwoserSupprt in RAP.
How to handle this in RAP?
Karsten
Re: Link support [message #6896 is a reply to message #5999] Tue, 13 March 2007 15:54 Go to previous messageGo to next message
Hi Karsten,
currently there is no BrowserSupport in the RAP Workbench and it is yet
unclear if there ever will be.
To open a browser window that shows a URL You could use the setText
method of the Browser widget to set a minimal HTML page that just
contains Your a-tag. Probably not the most beautiful way but it should work.
Once a Link widget is available, it could probably be used therefore.
Of course the most decent way would be to implement a custom widget. You
could have a look at Label and LabelLCA on how to implement this. The
qooxdoo Label widget also accepts some HTML, an a-tag at least.
Further information on how to implement Your own widget can also found
in the material from the EclipseCon RAP Tutorial
http://eclipsezilla.eclipsecon.org/attachment.cgi?id=468
http://eclipsezilla.eclipsecon.org/attachment.cgi?id=515
Hope that helps
Rüdiger
Karsten Panier wrote:
> Regards
> Karsten
Re: Link support [message #7273 is a reply to message #6896] Wed, 14 March 2007 13:19 Go to previous message
Hi Rüdiger,
thanks for your reply. Actual I use now a Dialog with a BrowserWidget.
If the user dislike it, I will try the solution with the minimal HTML
page with the href.
Also thanks for the Information about the Startup Page.
Karsten
Ruediger Herrmmann schrieb:
> Hi Karsten,
> work.
> Hope that helps
> Rüdiger
>> website. Now I am searching for something like <a href="someURL"
>> target="_blank"> in html. In an SWT based Appication I use
>> Regards
>> Karsten
Previous Topic:Changing the RAP Startup Page
Next Topic:Crazy Layout
Current Time: Sun Jul 13 00:00:05 EDT 2025
Powered by FUDForum. Page generated in 0.05098 seconds
