Home » Eclipse Projects » Plugin Development Environment (PDE) » Eclipse Plugin Update Site
Eclipse Plugin Update Site [message #67427] Tue, 07 July 2009 09:00 Go to next message
I am trying to create an update site to store my Lua Editor plug-in
(http://luaeclipse.luaforge.net/preview/update-site) and I am facing a lot
of difficulties.
When I try to use an Update Site project, my platform filters prevent me
from building the features for platforms other than mine.
When I try to use the 'Export' from the multi-platform pack, the resulting
update-site simply isn't recognized by the update manager.
Am I doing something stupid here? Is there any literature or documentation
available on deploying plug-ins?
Help would be greatly appreciated.
[]s
Jason Santos
Re: Eclipse Plugin Update Site [message #67449 is a reply to message #67427] Tue, 07 July 2009 10:22 Go to previous messageGo to next message
Luis Jason Santos wrote:
> lot of difficulties.
> resulting update-site simply isn't recognized by the update manager.
> documentation available on deploying plug-ins?
How are you installing the delta pack?
http://aniefer.blogspot.com/2009/06/using-deltapack-in-eclip se-35.html
Once you have the delta pack, you should be able to export things
properly using the feature export wizard. If you want to do things
headlessly via PDE Build, check out this blog:
http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Eclipse Plugin Update Site [message #67471 is a reply to message #67449] Tue, 07 July 2009 11:34 Go to previous message
My packages were created using the export wizard of the delta pack.
Although it has successfully built everything, for some reason the site
itself doesn't get recognized as an update-site. I believe fixing this
might be the shortest way to solve the problem.
What you mean by headlessly?
Thnks a lot!
Jason Santos
Re: Eclipse Plugin Update Site [message #599092 is a reply to message #67427] Tue, 07 July 2009 10:22 Go to previous message
Re: Eclipse Plugin Update Site [message #599102 is a reply to message #67449] Tue, 07 July 2009 11:34 Go to previous message
Thnks a lot!
Jason Santos
Previous Topic:Eclipse Plugin Update Site
Next Topic:PDE Build, p2 & bundles.info
Current Time: Mon Jul 14 10:24:48 EDT 2025
Powered by FUDForum. Page generated in 0.44040 seconds
