Home » Archived » BIRT » paramater setting via java code
paramater setting via java code [message #67414] Thu, 11 August 2005 14:36 Go to next message
So I want to set the values of my reports parameters with out popping a
ui. From what I understand I need to do something like
IGetParameterDefinitionTask task =
engine.createGetParameterDefinitionTask( report );
Collection params = task.getParameterDefns( true );
Then iterate the collection setting the values as I go?
Is this is fully supported at the moment?
Can I set the report data source via this mechanism?
Re: paramater setting via java code [message #67456 is a reply to message #67414] Thu, 11 August 2005 14:48 Go to previous message
Mike,
That collection object stores the parameter definition only. To pass in
the parameter, you have to collect your parameter values, associate them
with the right parameter name, put these pairs into a map object, and then
pass it to the engine before runing the report.
There are some sample code in viewer's EngineFragment.java file.
Jun Zhai
Previous Topic:User interaction with chart
Next Topic:Generate a Chart Report depending on User selection on webpage
Current Time: Fri Nov 07 03:08:35 EST 2025
Powered by FUDForum. Page generated in 0.07362 seconds
