Home » Language IDEs » ServerTools (WTP) » Generic Server: java.lang.NoClassDefFoundError
Generic Server: java.lang.NoClassDefFoundError [message #67396] Tue, 25 January 2005 06:20 Go to next message
can someone confirm that the Generic Server Support in the latest
Integration build ist TOTALLY broken?!
I tried my "old" oc4j config - which was working under the M2 and got a
Exception in thread "main" java.lang.NoClassDefFoundError:
oracle.oc4j.loader.boot.BootStrap
but oc4j is not supported from scratch so I tried JBoss and got:
Exception in thread "main" java.lang.NoClassDefFoundError: org/jboss/Main
Seems to me like someone changed something in the part that builds the
String[]VMarguments for the VMRunner is that correct?!
MAYBE this is only some Linux Problem...
Thnx for feedback...
Re: Generic Server: java.lang.NoClassDefFoundError [message #68680 is a reply to message #67396] Wed, 26 January 2005 16:50 Go to previous message
Originally posted by: gercan.REMOVEME.acm.org
It is not a suprise that your old oc4j config no longer works, the
structure of the server definition files changed quite. On the other
hand you should not be having any problems with the JBoss server
definiton provided in the build, but I must say I have not tried it on
Linux yet.
Gorkem Ercan
madmarauder wrote:
Previous Topic:Opening files in Project Explorer view doens't work with double click
Next Topic:Default folders in Dynamic Web Projects
Current Time: Sun Jul 27 08:45:54 EDT 2025
Powered by FUDForum. Page generated in 0.03945 seconds
