| Find out the root element [message #67394] |
Mon, 10 April 2006 02:42  |
Originally posted by: gilado74.gmail.com
Hi all,
I want to find out whether a given XSD schema contains more then one root
element.
currently, i did not find any "simple" utility in the API that will do the
job.
I wrote code that will handle it, but it's not handle properly all
possible cases.
my questions are:
1) There is any "simple" utility in the API that return the list of the
root elements ( not .getElementDeclarations()) or somthing similar ?
2) in case the first question is no. Why the following code:
private XSDElementDeclaration findRootElement(XSDSchema schema)
XSDElementDeclaration elementDeclaration;
Hashtable rootElementHash = new Hashtable();
Object o;
String name;
String qName;
// in case there is only one element in the root level, should be
the root element
if(schema.getElementDeclarations().size() == 1)
return
(XSDElementDeclaration)schema.getElementDeclarations().itera tor().next();
// insert all suspicious root elements into hash table
for (Iterator i =
schema.getElementDeclarations().iterator();i.hasNext();)
elementDeclaration=(XSDElementDeclaration)i.next();
rootElementHash.put(elementDeclaration.getName(),elementDecl aration);
//the last item that left in the hash table is the root element
for (Iterator i =
schema.getElementDeclarations().iterator();i.hasNext();) // for each
element on the root level
for(TreeIterator j =
elementDeclaration.eAllContents();j.hasNext();) // for each element in
the sub tree under
// the the element in the root level
o = j.next();
if(o instanceof XSDElementDeclaration )
XSDElementDeclaration elemDec =
(XSDElementDeclaration)o;
qName = elemDec.getQName();
name = elemDec.getName();
if (name != null) // the element is not
reference thus no need to remove the object
continue;
if(qName != null &&
rootElementHash.containsKey(qName) ) // in case the element from the
sub tree exist
rootElementHash.remove(qName);
// in the hash table, remove the item from the table
if(rootElementHash.isEmpty())
throw new RuntimeException("no root element in the schema");
if(rootElementHash.size()==1)
return
(XSDElementDeclaration)rootElementHash.values().iterator().n ext();
throw new RuntimeException("more then one root element in the
schema");
return wrong answear ("more then one root element in the schema") for the
given schema: (I have already tested successfully the code with different
scheam with reference elements)
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:element name="purchaseOrder" type="PurchaseOrderType"/>
<xs:element name="comment" type="xs:string"/>
<xs:complexType name="PurchaseOrderType">
<xs:sequence>
<xs:element name="shipTo" type="USAddress"/>
<xs:element name="billTo" type="USAddress"/>
<xs:element ref="comment" minOccurs="0"/>
<xs:element name="items" type="Items"/>
</xs:sequence>
<xs:attribute name="orderDate" type="xs:date"/>
</xs:complexType>
<xs:complexType name="USAddress">
<xs:sequence>
<xs:element name="name" type="xs:string"/>
<xs:element name="street" type="xs:string"/>
<xs:element name="city" type="xs:string"/>
<xs:element name="state" type="xs:string"/>
<xs:element name="zip" type="xs:decimal"/>
</xs:sequence>
<xs:attribute name="country" type="xs:NMTOKEN" fixed="US"/>
</xs:complexType>
<xs:complexType name="Items">
<xs:sequence>
<xs:element name="item" minOccurs="0" maxOccurs="unbounded">
<xs:complexType>
<xs:sequence>
<xs:element name="productName" type="xs:string"/>
<xs:element name="quantity">
<xs:simpleType>
<xs:restriction base="xs:positiveInteger">
<xs:maxExclusive value="100"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="USPrice" type="xs:decimal"/>
<xs:element name="shipDate" type="xs:date" minOccurs="0"/>
</xs:sequence>
<xs:attribute name="partNum" type="SKU" use="required"/>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
<!-- Stock Keeping Unit, a code for identifying products -->
<xs:simpleType name="SKU">
<xs:restriction base="xs:string">
<xs:pattern value="\d{3}-[A-Z]{2}"/>
</xs:restriction>
</xs:simpleType>
</xs:schema>
what is wrong with my code ?
Gilad
| Re: Find out the root element [message #67415 is a reply to message #67394] |
Mon, 10 April 2006 08:01   |
Gilad,
Any global element can be the root element of an instance, so I don't
know how you define a "root" element to be more restrictive than that.
Can you elaborate on what you mean by the term root element.
Gilad wrote:
> Hi all,
> root element.
> the job.
> possible cases.
> my questions are:
> the root elements ( not .getElementDeclarations()) or somthing similar ?
> Object o;
> String name;
> String qName;
> be the root element if(schema.getElementDeclarations().size()
> == 1)
> return
> for (Iterator i =
> for (Iterator i =
> element in the sub tree under
> o = j.next();
> continue;
> if(qName != null &&
> the sub tree exist
> rootElementHash.remove(qName); // in the
> return
> schema");
> the given schema: (I have already tested successfully the code with
> different scheam with reference elements)
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence>
> <xs:complexType>
> <xs:sequence>
> <xs:simpleType>
> <xs:restriction
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
> minOccurs="0"/>
> </xs:sequence>
> use="required"/>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:restriction>
> </xs:simpleType>
> </xs:schema>
> Gilad
| Re: Find out the root element [message #67477 is a reply to message #67415] |
Mon, 10 April 2006 10:11  |
Originally posted by: patrick.mcgovern.unisys.cm
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:e1dheu$174$1@utils.eclipse.org...
> Gilad,
> Any global element can be the root element of an instance, so I don't know
> how you define a "root" element to be more restrictive than that. Can you
Does he mean an element that doesnt have a parent?
> Gilad wrote:
>> Hi all,
>> element.
>> the job.
>> possible cases.
>> my questions are:
>> Object o;
>> String name;
>> String qName;
>> the root element if(schema.getElementDeclarations().size() == 1)
>> return
>> for (Iterator i =
>> for (Iterator i =
>> { // the the
>> o = j.next();
>> continue;
>> if(qName != null &&
>> the sub tree exist
>> return
>> schema");
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> <xs:sequence>
>> <xs:complexType>
>> <xs:sequence>
>> <xs:simpleType>
>> <xs:restriction
>> </xs:restriction>
>> </xs:simpleType>
>> </xs:element>
>> minOccurs="0"/>
>> </xs:sequence>
>> use="required"/>
>> </xs:complexType>
>> </xs:element>
>> </xs:sequence>
>> </xs:complexType>
>> </xs:restriction>
>> </xs:simpleType>
>> </xs:schema>
>> Thanks,
>> Gilad
| Re: Find out the root element [message #597872 is a reply to message #67394] |
Gilad,
Gilad wrote:
> Hi all,
> root element.
> the job.
> possible cases.
> my questions are:
> Object o;
> String name;
> String qName;
> == 1)
> return
> for (Iterator i =
> for (Iterator i =
> o = j.next();
> continue;
> if(qName != null &&
> the sub tree exist
> return
> schema");
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence>
> <xs:complexType>
> <xs:sequence>
> <xs:simpleType>
> <xs:restriction
> </xs:restriction>
> </xs:simpleType>
> </xs:element>
> minOccurs="0"/>
> </xs:sequence>
> use="required"/>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> </xs:restriction>
> </xs:simpleType>
> </xs:schema>
> Gilad
| Re: Find out the root element [message #597879 is a reply to message #67415] |
Mon, 10 April 2006 09:07  |
i meant, for my needs i need to distinguish between elements that contains
sub elements and elements that referenced by other elements in the schema.
E.G.
both "purchaseOrder" and "comment" are in root level but the "comment"
element is referenced from the "PurchaseOrderType" complexType thus it
can't be root element of XML (for my application).
<xs:sequence>
</xs:sequence>
</xs:complexType>
| Re: Find out the root element [message #597882 is a reply to message #67434] |
Mon, 10 April 2006 09:47  |
Gilad,
Elements which contain sub elements can also be referenced by other
elements, so this characterization doesn't help make things much
clearer. You can analyze the type of an element to understand if it's
complex or simple and you can use XSDUtil.UsageCrossReferencer to find
uses of all global elements to decide if any particular type of use
makes the element not a root.
> contains sub elements and elements that referenced by other elements
> in the schema.
> E.G. both "purchaseOrder" and "comment" are in root level but the
> "comment" element is referenced from the "PurchaseOrderType"
> complexType thus it can't be root element of XML (for my application).
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
| Re: Find out the root element [message #597890 is a reply to message #67415] |
> Gilad,
> Gilad wrote:
>> Hi all,
>> element.
>> the job.
>> possible cases.
>> my questions are:
>> Object o;
>> String name;
>> String qName;
>> return
>> for (Iterator i =
>> for (Iterator i =
>> { // the the
>> o = j.next();
>> continue;
>> if(qName != null &&
>> the sub tree exist
>> return
>> schema");
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> <xs:sequence>
>> <xs:complexType>
>> <xs:sequence>
>> <xs:simpleType>
>> <xs:restriction
>> </xs:restriction>
>> </xs:simpleType>
>> </xs:element>
>> minOccurs="0"/>
>> </xs:sequence>
>> use="required"/>
>> </xs:complexType>
>> </xs:element>
>> </xs:sequence>
>> </xs:complexType>
>> </xs:restriction>
>> </xs:simpleType>
>> </xs:schema>
>> Thanks,
>> Gilad
FUDForum. Page generated in 0.42441 seconds
