Home » Archived » M2M (model-to-model transformation) » Injection problem in qATL
| Injection problem in qATL [message #67381] |
Thu, 29 November 2007 03:32  |
Hi all, I have at first sight a basic problem, but after 2 days I didn't
even resolve it.
I am developing an HOT transformation that I want to call directly from
the weaving panel (as in qATL).
The problem is that when I try to inject ATL code into my resulting ATL
model, I get an exception (the stack trace of the
exception is attached at the end of the post).
I even tried to modify the SimpleATLtoATL.atl transformation of the
plug-in org.eclipse.gmt.weaver.qatl, but it did not work.
Notice that I modify ONLY the transformation, the source code of the
plug-in remains the same.
I modified only the following rule:
rule InPatternElement {
from --elements of a model -- source Element
amw: AMW!InputElement
to
atl: ATL!InPattern (
elements <- element
element : ATL!SimpleInPatternElement(
varName <- amw.getVarName(),
type <- aType
-- -- creates a new model element because it may have repeated elements
aType : ATL!OclModelElement (
name <- thisModule.getLeftInstance(amw.element.ref).name,
model <-
thisModule.resolveTemp(AMW!InModelRef.allInstancesFrom('IN') - >select ( e |
true)->first(),'ametamodel')
to 'my rule':
to
elements <- element,
filter <- 'true'.inject('OUT', 'ebnf2', 'ATL-oclExpression')
-- this is where the two rules differ
type <- aType
model <-
Can anyone explain me why the injection does not work and how can I
resolve this problem?
Thanks, Ivano
The stack trace of the exception is:
GRAVE: ****** BEGIN Stack Trace
GRAVE: exception:
GRAVE: null
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source)
org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:59)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:325)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:161)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
org.eclipse.gmt.weaver.transformation.util.TransformationUti l.executeTransfo(TransformationUtil.java:103)
org.eclipse.gmt.weaver.transformation.panel.TransformationWe avingPanel$TAction.run(TransformationWeavingPanel.java:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Caused by: java.lang.NullPointerException
org.eclipse.m2m.atl.engine.vm.nativelib.ASMString.inject(ASM String.java:287)
... 52 more
GRAVE: A.main() : ??#27 null
GRAVE: local variables = {self=SimpleATLtoATL : ASMModule}
GRAVE: local stack = []
GRAVE: A.__exec__() : ??#58 null
GRAVE: local variables = {e=TransientLink {rule = 'InPatternElement',
sourceElements = {amw = IN!SAcomponent}, targetElements = {element =
OUT!<unnamed>, aType = OUT!<notnamedyet>, atl = OUT!<unnamed>}, variables
= {}}, self=SimpleATLtoATL : ASMModule}
GRAVE: A.__applyInPatternElement(1 : NTransientLink;) : ??#28 138:15-138:65
GRAVE: local variables = {atl=OUT!<unnamed>, amw=IN!SAcomponent,
link=TransientLink {rule = 'InPatternElement', sourceElements = {amw =
IN!SAcomponent}, targetElements = {element = OUT!<unnamed>, aType =
OUT!<notnamedyet>, atl = OUT!<unnamed>}, variables = {}},
self=SimpleATLtoATL : ASMModule, aType=OUT!<notnamedyet>,
element=OUT!<unnamed>}
GRAVE: local stack = [OUT!<unnamed>, OUT!<unnamed>, SimpleATLtoATL :
ASMModule]
GRAVE: NativeOperation public static
org.eclipse.m2m.atl.engine.vm.nativelib.ASMString.inject(org .eclipse.m2m.atl.engine.vm.StackFrame,org.eclipse.m2m.atl.en gine.vm.nativelib.ASMString,org.eclipse.m2m.atl.engine.vm.na tivelib.ASMString,org.eclipse.m2m.atl.engine.vm.nativelib.AS MString,org.eclipse.m2m.atl.engine.vm.nativelib.ASMString)
GRAVE: args = ['true', 'OUT', 'ebnf2', 'ATL-oclExpression']
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
GRAVE: null
java.lang.RuntimeException
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:185)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:77)
org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:67)
Caused by: java.lang.reflect.InvocationTargetException
... 48 more
... 52 more
| Re: [ATL] Injection problem in qATL [message #67692 is a reply to message #67381] |
Thu, 29 November 2007 18:29   |
Hello Ivano,
Could you please remember to prefix the subject of your ATL-related
posts to the M2M newsgroup with [ATL] as I did in this reply?
Additionally, your question may also be of interest to the AMW newsgroup
readers. Therefore, I added it in copy.
The problem you encountered seems to occur because injection of 'true'
cannot proceed. This may be because the ATL parser is not available in
the ant launch configuration classpath. You could try adding it.
Alternatively, you could also directly write the code that will create
the expression you want in the target pattern. For instance, to add 'true':
to
filter <- filter
filter : ATL!BooleanExp (
booleanSymbol <- true
type <- aType
elements
model <-
You may not want to build your target pattern elements by just looking
at the metamodel. Then, you can write an ATL file (e.g., a query), and
inject it to see what elements you have to create.
Frédéric Jouault
> even resolve it.
> model, I get an exception (the stack trace of the exception is attached
> to
> elements <- element
> type <- aType
> elements
> model <-
> to 'my rule':
> to
> 'ATL-oclExpression') -- this is where the two
> rules differ
> type <- aType
> elements
> model <-
> Thanks, Ivano
> GRAVE: exception: GRAVE: null
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 52 more
> 'InPatternElement', sourceElements = {amw = IN!SAcomponent},
> targetElements = {element = OUT!<unnamed>, aType = OUT!<notnamedyet>,
> atl = OUT!<unnamed>}, variables = {}}, self=SimpleATLtoATL : ASMModule}
> ASMModule]
> allow continuation after errors).
> GRAVE: null
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 48 more
> at
> ... 52 more
| Re: [ATL] Injection problem in qATL [message #68199 is a reply to message #68129] |
Tue, 04 December 2007 11:32   |
Originally posted by: mddfabro.ilog.fr
Hi Ivano,
Did you try to execute the transformation using an ATL launch
configuration, ie, outside from the plug-in?
You can do that by copying the transformation into your workspace and
setting up your input and output models as it is done for other ATL
transformations.
This would help us to verify if the problem comes from the AMW calls to
the ATL transformations or if it is a more general problem.
Marcos.
ivano wrote:
> Hi all, I have edited the source HOT transformation SimpleAtl2ATL from
> the plug-in qATL to graphically develope ATL transformations.
> All works fine, but if I try to inject something I get NullPointer
> Exceptions.
> For example I tried to inject a simple condition into every rule:
> atl.filter <- 'true'.inject('OUT', 'ebnf2', 'ATL-oclExpression');
> Does anyone know why I cannot use injection direclty from AMW?
> Regards, Ivano
| Re: [ATL] Injection problem in qATL [message #68223 is a reply to message #68199] |
Wed, 05 December 2007 03:47   |
Hi Marcos, I have just tried the modified simpleATL2ATL transformation
outside AMW and it all worked fine.
I hope it is only a configuration issue, I think that AMW does not find
ebnf injector, but it is only a hypothesis...
Regards, Ivano
Marcos Didonet Del Fabro wrote:
> Hi Ivano,
> transformations.
> Marcos.
>> Exceptions.
>> Regards, Ivano
| Re: [ATL] Injection problem in qATL [message #69422 is a reply to message #68223] |
Thu, 13 December 2007 03:38   |
Hi Marcos, would you try to inject ATL code as I did (unsuccesfully :/ )?
It is a very important feature of my transformations and It still does not
work...
Regard, Ivano
> Regards, Ivano
>> Hi Ivano,
>> transformations.
>> Regards,
>> Marcos.
>>> Exceptions.
>>> Regards, Ivano
>>>Hi Marcos,
| Re: [ATL] Injection problem in qATL [message #69443 is a reply to message #69422] |
Thu, 13 December 2007 04:29   |
Hi Ivano,
the problem was that the AMW model handler did not have a modelLoader
associated with it, thus it could not load the ebnf2 injector.
I changed the code by associating an EMF model loader with the AMW model
handler. This code will be refactored later.
I tested here with these modifications and it worked well. You can check
out the amw4atl plug-in from the CVS to verify if it works for you.
Marcos.
> not work...
> Regard, Ivano
>> find ebnf injector, but it is only a hypothesis...
>> Regards, Ivano
>>> Hi Ivano,
>>> transformations.
>>> to the ATL transformations or if it is a more general problem.
>>> Regards,
>>> Marcos.
>>>> from the plug-in qATL to graphically develope ATL transformations.
>>>> Exceptions.
>>>> Regards, Ivano
>>>> Hi Marcos,
| Re: [ATL] Injection problem in qATL [message #70169 is a reply to message #69443] |
Sat, 22 December 2007 11:31   |
Hi Marcos,
I finally checked out the amw4atl plug-in from the CVS and everything
worked
well, thank you very much.
I hope I will not bother you with this issues!
Regards, Ivano
> Hi Ivano,
> Marcos.
>> not work...
>> Regard, Ivano
>>> Regards, Ivano
>>>> Hi Ivano,
>>>> transformations.
>>>> Regards,
>>>> Marcos.
>>>>> Exceptions.
>>>>> Regards, Ivano
| Re: [ATL] Injection problem in qATL [message #70429 is a reply to message #70230] |
Fri, 04 January 2008 07:42   |
Hi Ivano,
the code of the rules with error are in 'normal' ATL files or the code
is injected using the .inject ('OUT','ebnf', <exp>) method?
There are two things to pay attention when developing called and lazy rules:
- in called rules, you should have a return expression at the end of the
imperative part;
- in lazy rules, the type of the input pattern should be respected.
Marcos
Ivano wrote:
> Hi Marcos, I am using the modified version of AMW4ATL and I still have
> problems:
> when a called rule (that returns something) is executed I get an
> EmptyStack exception;
> when a lazy rule is executed I get an ClassCastException;
> These exceptions arise only if I use the modified version of AMW4ATL, do
> you have any idea about this issue??
> Thank you, Ivano
| Re: [ATL] Injection problem in qATL [message #70505 is a reply to message #70429] |
Sat, 05 January 2008 09:45   |
Hi Marcos, this is one of my rules:
rule createBinding(featName : MOF!"String", element :
ATL!SimpleOutPatternElement, var : ATL!VariableDeclaration) { -- :
ATL!Binding
to
atl : ATL!Binding(
outPatternElement <- element,
propertyName <- featName,
value <- val
val : ATL!NavigationOrAttributeCallExp(
name <- featName,
source <- valSource
valSource : ATL!VariableExp(
referredVariable <- var
do {
atl;
The calling of the rule works, but somewhere in the return elements goes
wrong;
in fact everything works if I remove the "to" section of the rule and I
print the input parameters in the "do" section.
I ask this to you, because I tested the same rule with the old AMW4ATL and
everything works correctly...
Do you have any suggestion?
Regards, Ivano
> Hi Ivano,
> imperative part;
> Marcos
>> problems:
>> Thank you, Ivano
| Re: [ATL] Injection problem in qATL [message #70636 is a reply to message #70505] |
Mon, 07 January 2008 04:36  |
Hi Ivano,
I didn't manage to reproduce the error here.
I will investigate it with different examples and configurations. I keep
you informed.
Marcos.
> ATL!Binding
> to
> atl : ATL!Binding(
> value <- val
> name <- featName, source <- valSource
> do {
> atl;
> wrong;
> and everything works correctly...
> Regards, Ivano
>> Hi Ivano,
>> rules:
>> the imperative part;
>> Regards,
>> Marcos
>>> have problems:
>>> do you have any idea about this issue??
>>> Thank you, Ivano
Current Time: Fri Nov 21 22:13:39 EST 2025
Powered by FUDForum. Page generated in 0.06886 seconds
