Home » Newcomers » Newcomers » Ant-support Classes Seem To Be Missing
Ant-support Classes Seem To Be Missing [message #67366] Sun, 22 May 2005 12:33 Go to next message
I have just installed Eclipse 3.0.2 on Fedora RC2, and cannot execute
ant build files. I am using j2sdk1.4.2_06.
Error messages I am getting are:
1. In response to Run | External Tools | build-file
Referenced class path provider does not exist:
org.eclipse.ant.ui.AntClasspathProvider
2. In response to Run | External Tools...
Exception occurred creating launch configuration tabs
Reason:
No tab group defined for launch configuration type
org.eclipse.ant.AntLaunchConfigurationType
What must I do to enable support for ant ?
Bill.
Re: Ant-support Classes Seem To Be Missing [message #67390 is a reply to message #67366] Sun, 22 May 2005 13:54 Go to previous messageGo to next message
You should not have to do anything special to get your Ant support working.
This appears to be https://bugs.eclipse.org/bugs/show_bug.cgi?id=60278
(You have a corrupted Eclipse registry...see comment #2)
HTH
Darins
"bwinspur" <bwinspur@wynnon.com> wrote in message
news:d6qcc0$c98$1@news.eclipse.org...
>I have just installed Eclipse 3.0.2 on Fedora RC2, and cannot execute ant
> Reason:
> Bill.
Re: Ant-support Classes Seem To Be Missing [message #67410 is a reply to message #67390] Sun, 22 May 2005 13:37 Go to previous messageGo to next message
> HTH
> Darins
>>Reason:
>>Bill.
Darin, Thanks.
I have accidentally tried to re-use the workspace, so this
could be the problem. However, when I looked for .registry
to delete, I could not find dir .config or file .registry
on my system. Hoping it helps, a listing of the top dir in my
eclipse 3.0.2 installation follows:
[root@local eclipse]# pwd
/usr/local/share/eclipse
[root@local eclipse]# ls -al
total 116
drwxr-xr-x 7 root root 4096 May 22 10:31 .
drwxr-xr-x 6 root root 4096 May 19 23:22 ..
drwxrwxr-x 7 root root 4096 May 20 23:49 configuration
-rw-rw-r-- 1 root root 15049 Mar 11 07:18 cpl-v10.html
-rwxr-xr-x 1 root root 27178 Mar 11 07:18 eclipse
-rw-rw-r-- 1 root root 59 Mar 11 07:18 .eclipseproduct
drwxr-xr-x 10 root root 4096 May 20 23:20 features
-rw-rw-r-- 1 root root 10489 Mar 11 07:18 icon.xpm
drwxrwxr-x 2 root root 4096 May 20 22:46 links
-rw-rw-r-- 1 root root 5810 Mar 11 07:18 notice.html
drwxr-xr-x 86 root root 4096 May 20 23:20 plugins
drwxrwxr-x 2 root root 4096 Mar 11 07:18 readme
-rw-rw-r-- 1 root root 19465 Mar 11 07:18 startup.jar
Im a bit reluctant to re-install eclipse, since I've
downloaded a few of my purchased plugins already. However,
I may have to do that if another workaround is not available.
Bill.
Re: Ant-support Classes Seem To Be Missing [message #67470 is a reply to message #67410] Sun, 22 May 2005 15:57 Go to previous message
FWIW: I have another workaround.
1. Started eclipse with the -clean option and was able to execute
my build file without problems.
2. Then I started another copy of eclipse (without the -clean option),
which said 'workspace in use, etc'. Exited out of the 2nd copy.
3. First copy still able to run my build file.
4. Restarted eclipse (without -clean) which can still run my build.
Conclusion: it probably was not an attempt to run two copies of
eclipse on the same workspace that caused my problem, but -clean
can get me past it.
>> working.
>> HTH
>> Darins
>>> Reason:
>>> Bill.
> Darin, Thanks.
> total 116
> Bill.
Previous Topic:For get sourcecode from cvs ,how to set proxy for eclipse??
Next Topic:Open a .java file without adding it to a package?
Current Time: Fri Jul 18 05:51:05 EDT 2025
Powered by FUDForum. Page generated in 0.15391 seconds
