| Ant-support Classes Seem To Be Missing [message #67366] | Sun, 22 May 2005 12:33  |  |
| Eclipse User  |  |  |  |  | I have just installed Eclipse 3.0.2 on Fedora RC2, and cannot execute ant build files. I am using j2sdk1.4.2_06.
 Error messages I am getting are:
 1. In response to Run | External Tools | build-file
 Referenced class path provider does not exist:
 org.eclipse.ant.ui.AntClasspathProvider
 2. In response to Run | External Tools...
 Exception occurred creating launch configuration tabs
 Reason:
 No tab group defined for launch configuration type
 org.eclipse.ant.AntLaunchConfigurationType
 What must I do to enable support for ant ?
 Bill.
| Re: Ant-support Classes Seem To Be Missing [message #67470 is a reply to message #67410] | Sun, 22 May 2005 15:57  |  |
| Eclipse User  |  |  |  |  | FWIW: I have another workaround. 1. Started eclipse with the -clean option and was able to execute
 my build file without problems.
 2. Then I started another copy of eclipse (without the -clean option),
 which said 'workspace in use, etc'. Exited out of the 2nd copy.
 3. First copy still able to run my build file.
 4. Restarted eclipse (without -clean) which can still run my build.
 Conclusion: it probably was not an attempt to run two copies of
 eclipse on the same workspace that caused my problem, but -clean
 can get me past it.
 bwinspur wrote:
 > Darin Swanson wrote:
 >> You should not have to do anything special to get your Ant support
 >> working.
 >> This appears to be https://bugs.eclipse.org/bugs/show_bug.cgi?id=60278
 >> (You have a corrupted Eclipse registry...see comment #2)
 >> HTH
 >> Darins
 >> "bwinspur" <bwinspur@wynnon.com> wrote in message
 >> news:d6qcc0$c98$1@news.eclipse.org...
 >>> Reason:
 >>> Bill.
 > Darin, Thanks.
 > I have accidentally tried to re-use the workspace, so this
 > could be the problem. However, when I looked for .registry
 > to delete, I could not find dir .config or file .registry
 > on my system. Hoping it helps, a listing of the top dir in my
 > eclipse 3.0.2 installation follows:
 > [root@local eclipse]# pwd
 > /usr/local/share/eclipse
 > [root@local eclipse]# ls -al
 > total 116
 > drwxr-xr-x   7 root root  4096 May 22 10:31 .
 > drwxr-xr-x   6 root root  4096 May 19 23:22 ..
 > drwxrwxr-x   7 root root  4096 May 20 23:49 configuration
 > -rw-rw-r--   1 root root 15049 Mar 11 07:18 cpl-v10.html
 > -rwxr-xr-x   1 root root 27178 Mar 11 07:18 eclipse
 > -rw-rw-r--   1 root root    59 Mar 11 07:18 .eclipseproduct
 > drwxr-xr-x  10 root root  4096 May 20 23:20 features
 > -rw-rw-r--   1 root root 10489 Mar 11 07:18 icon.xpm
 > drwxrwxr-x   2 root root  4096 May 20 22:46 links
 > -rw-rw-r--   1 root root  5810 Mar 11 07:18 notice.html
 > drwxr-xr-x  86 root root  4096 May 20 23:20 plugins
 > drwxrwxr-x   2 root root  4096 Mar 11 07:18 readme
 > -rw-rw-r--   1 root root 19465 Mar 11 07:18 startup.jar
 > Im a bit reluctant to re-install eclipse, since I've
 > downloaded a few of my purchased plugins already. However,
 > I may have to do that if another workaround is not available.
 > Bill.
FUDForum. Page generated in 0.08671 seconds
