Is it possible to insert JavaEditor example into Dialog??? [message #67356] |
Wed, 25 June 2003 10:01 |
Hello group. I was trying to insert JavaEditor example into Dialog.
Here is code:
protected Control createDialogArea(Composite parent)
Composite container =
(Composite)super.createShell();//.createDialogArea(parent);
GridLayout layout = new GridLayout();
container.setLayout(layout);
layout.numColumns = 1;
layout.verticalSpacing = 1;
javaeditor.JavaEditor editor = new javaeditor.JavaEditor();
editor.initializeEditor();
editor.setInput(container);
editor.createPartControl(container);
return container;
During runtime when getting into this method i got the exception:
java.lang.NullPointerException:
at org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol
(AbstractTextEditor.java:2039)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEdito
r.java:53)
org.eclipse.ui.editors.text.TextEditor.createPartControl(Tex tEditor.java:746
I assume the reason is that getSite() probably returns null since exception
occurs in class AbstractTextEditor in this line:
if (fEditorContextMenuId != null)
-> getSite().registerContextMenu(fEditorContextMenuId, manager,
getSelectionProvider());
Another direction, when i use example where JAvaEditor is extension, where
can i see how it initilized ?
Does anyone has an idea how to handle to make editor visible in dialog or on
workbench with the String in need to edit?
Asaf
FUDForum. Page generated in 0.05245 seconds
