Home » Modeling » GMF (Graphical Modeling Framework) » headless usage of GMF rendering
headless usage of GMF rendering [message #67322] Sat, 21 October 2006 17:45 Go to next message
Originally posted by: alexander.schwartzonline.de
I know this question might sound a little bit strange:
Assume we are given a model instance file and a corressponding notation
file. Is there a change to produce an image of the given instance
using the GMF API without launching the Eclipse UI?
Alex
Re: headless usage of GMF rendering [message #68086 is a reply to message #67322] Mon, 23 October 2006 13:18 Go to previous messageGo to next message
Alex,
You can produce an image without bringing up an editor within Eclipse if
this is any help.
See OffscreenEditPartFactory and CopyToImageUtil for details.
Cherie
Alex Schwartz wrote:
> Alex
Re: headless usage of GMF rendering [message #71221 is a reply to message #68086] Sat, 28 October 2006 06:46 Go to previous messageGo to next message
Hello Cherie,
> this is any help.
Thanks for your hint. I found these classes and created a headless RCP
which runs the image conversion.
Unfortunately I run into some problems with the initialization.
Loading the class ImageFileFormat fails with the following exception:
org.osgi.framework.BundleException: Exception in
org.eclipse.gmf.runtime.diagram.ui.internal.DiagramUIPlugin. start() of
bundle org.eclipse.gmf.runtime.diagram.ui.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1014)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:388)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
de.schwartzonline.gmf.mavendependencies.diagram.MavenDepende nciesDiagramImageExporter. <init>(MavenDependenciesDiagramImageExporter.java:31)
de.schwartzonline.gmf.mavendependencies.offscreen.rcp.MavenD ependencyOffscreenRendererApplication.run(MavenDependencyOff screenRendererApplication.java:49)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.eclipse.jface.util.Assert$AssertionFailedException: null
argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:150)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:126)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:273)
at org.eclipse.jface.resource.FontRegistry.<init>(FontRegistry.java:288)
org.eclipse.jface.resource.JFaceResources.getFontRegistry(JF aceResources.java:267)
org.eclipse.jface.resource.JFaceResources.getDefaultFont(JFa ceResources.java:220)
org.eclipse.gmf.runtime.diagram.ui.preferences.AppearancePre ferencePage.setDefaultFontPreference(AppearancePreferencePag e.java:228)
org.eclipse.gmf.runtime.diagram.ui.preferences.AppearancePre ferencePage.initDefaults(AppearancePreferencePage.java:169)
org.eclipse.gmf.runtime.diagram.ui.internal.DiagramUIPlugin. initializeDefaultDiagramPreferenceStore(DiagramUIPlugin.java :95)
org.eclipse.gmf.runtime.diagram.ui.internal.DiagramUIPlugin. start(DiagramUIPlugin.java:76)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
.... 28 more
Root exception:
org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
Do I have to add some initialization steps?
Alex
Re: headless usage of GMF rendering [message #71700 is a reply to message #71221] Mon, 30 October 2006 12:02 Go to previous messageGo to next message
Alex,
When the Diagram UI plugin starts up it initializes the preference store
with font values. It is calling JFaceResources.getDefaultFont() and
when a new font registry is created in SWT it requires a Display.
We have not supported this use case in the past, but I don't see why we
shouldn't be able to support it assuming SWT supports this somehow.
Maybe there is another way we can get the default font. I would suggest
you create a bugzilla and someone can look into it.
Cherie
> Hello Cherie,
>> if this is any help.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> argument;
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 28 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Best regards,
> Alex
Re: headless usage of GMF rendering [message #74210 is a reply to message #71700] Fri, 03 November 2006 15:25 Go to previous message
Hello Cherie,
Thanks for analyzing the problem.
I entered the bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=163380
Alex
Previous Topic:Border item as a container
Next Topic:Obtain active editor name from paint method
Current Time: Tue Jul 08 12:49:04 EDT 2025
Powered by FUDForum. Page generated in 0.03221 seconds
