Home » Language IDEs » AspectJ » OutOfMemoryError
OutOfMemoryError [message #67289] |
Mon, 16 October 2006 06:00  |
I am trying to weave an aspect into a large .jar file (52 MB), to which
I do not have the source, but am running into OutOfMemoryError.
As target aspectj runtime version, which I can not influence, is 1.2.2.,
I installed Eclipse 3.0.2 and perform an online update of 1.2.2. Shortly
after compiling, the CPU consumption is 100% and the virtual memory gets
as high as 1.9 GB before Eclipse crashes. I played around with -vmargs,
but expanding heap only defers the seemingly inevitable OutOfMemoryError.
I also tried using ajc from the command line with AspectJ 1.5.2a. But
it, too, reports the same (output provided further on).
Java environment is IBM 1.4.2.
Is my jar file just too big? Any suggestions?
Thanks, chris
Output from command-line ajc:
JVMST109: Insufficient space in Javaheap to satisfy allocation request
ABORT
Exception thrown from AspectJ 1.5.2a
This might be logged as a bug already -- find current bugs at
http://bugs.eclipse.org/bugs/buglist.cgi?product=AspectJ& ;component=Compiler
Bugs for exceptions thrown have titles File:line from the top stack,
e.g., "SomeFile.java:243"
If you don't find the exception below in a bug, please add a new bug
at http://bugs.eclipse.org/bugs/enter_bug.cgi?product=AspectJ
To make the bug a priority, please include a test program
that can reproduce this exception.
when batch building BuildConfig[null] #Files=1
null
java.lang.OutOfMemoryError
org.aspectj.util.FileUtil.readAsByteArray(FileUtil.java(Comp iled Code))
org.aspectj.weaver.bcel.BcelWeaver.addJarFile(BcelWeaver.jav a(Compiled
Code))
org.aspectj.ajdt.internal.core.builder.AjBuildManager.initBc elWorld(AjBuildManager.java:726)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.doBuil d(AjBuildManager.java:223)
org.aspectj.ajdt.internal.core.builder.AjBuildManager.batchB uild(AjBuildManager.java:163)
at org.aspectj.ajdt.ajc.AjdtCommand.doCommand(AjdtCommand.java: 112)
at org.aspectj.ajdt.ajc.AjdtCommand.runCommand(AjdtCommand.java :60)
at org.aspectj.tools.ajc.Main.run(Main.java:367)
at org.aspectj.tools.ajc.Main.runMain(Main.java:246)
at org.aspectj.tools.ajc.Main.main(Main.java:86)
Re: OutOfMemoryError [message #67301 is a reply to message #67289] |
Mon, 16 October 2006 08:42  |
In the meantime, I compile by setting heap size with "-Xmx1024M".
I also added very, very many jars to the classpath which are needed to
resolve classes and interfaces.
Thanks, chris
Chris Giblin wrote:
> Thanks, chris
> ABORT
> null
> at
> at
> Code))
> at
> at
> at
Re: OutOfMemoryError [message #595071 is a reply to message #67289] |
Thanks, chris
Chris Giblin wrote:
> Thanks, chris
> ABORT
> null
> at
> at
> Code))
> at
> at
> at
Current Time: Wed Sep 03 00:13:00 EDT 2025
Powered by FUDForum. Page generated in 0.04244 seconds
