| Code Coverage [message #67208] |
Thu, 20 April 2006 13:32   |
Eclipse User  |
I am using the Code Coverage tool that comes with TPTP. I am using Eclipse
3.1.2 and TPTP 4.1.0.1. I am seeing inconsistent result when running my
testes.
1) When collecting coverage data manually running eclipse, something the
all method within a class is collected, but sometime some of the methods
that arent call doesnt show up in the report.
2) When collecting coverage data using JUnit (The JUnit test case arent
part of TPTPs JUnit), the test method within the JUnit test case doesnt
shows up in the report, and the methods that are call from the JUnit test
method doesnt show up as well, where it shows up in the manual test run.
Is anyone else having these problems?
Patrick
| Re: Code Coverage [message #69269 is a reply to message #67208] |
Mon, 01 May 2006 15:55   |
Eclipse User  |
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 006D6BCC85257161_=
Content-Type: text/plain; charset="US-ASCII"
Check your filters and make sure you're not accidentally filtering out the
information you need.  To access your filter set, click on the profile
button, select 'Profile...' -> select your launch configuration -> select
the 'profiling' tab -> click on your profiling set -> edit -> next ->
select the profiling options you like -> next -> check your filterset here
and make sure you're not filter out the things you're interested in ->
finish -> profile.
 Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Check your filters and make sure you're
not accidentally filtering out the information you need.  To access
your filter set, click on the profile button, select 'Profile...' ->
select your launch configuration -> select the 'profiling' tab ->
click on your profiling set -> edit -> next -> select the profiling
options you like -> next -> check your filterset here and make sure
you're not filter out the things you're interested in -> finish ->
profile.</font>
<br>
<br><font size=2 face="sans-serif"> Navid Mehregani</font>
--=_alternative 006D6BCC85257161_=--
FUDForum. Page generated in 0.55500 seconds
