Home » Eclipse Projects » Mylyn » Moving Mylyn task data to new workspace
Moving Mylyn task data to new workspace [message #67135] Fri, 20 March 2009 11:12 Go to next message
Originally posted by: jonathan.magma.ca
I want to move my Mylyn tasks permanently from one Eclipse workspace to
another. Both workspaces are accessed with Mylyn 3.1. Is it safe to just
copy the .mylyn sub-directory of .metadata from the old workspace to the
new one or is some other procedure required?
Jonathan
Re: Moving Mylyn task data to new workspace [message #67146 is a reply to message #67135] Fri, 20 March 2009 12:01 Go to previous messageGo to next message
How about File / Export --> File / Import?
This is the standard way, but copying the .mylyn sub-directory could also work.
Cheers, Jörg
Re: Moving Mylyn task data to new workspace [message #67154 is a reply to message #67146] Fri, 20 March 2009 12:54 Go to previous messageGo to next message
> Cheers, Jörg
Thanks for the pointer. Safer to do things the standard way!
Jonathan
Re: Moving Mylyn task data to new workspace [message #67163 is a reply to message #67154] Fri, 20 March 2009 23:10 Go to previous message
Both methods should have the same result. In Mylyn 3.1 File Import / Export
will import or create a zip archive of the .mylyn folder.
Steffen
>> work.
>> Cheers, Jörg
> Jonathan
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Moving Mylyn task data to new workspace [message #596961 is a reply to message #67135] Fri, 20 March 2009 12:01 Go to previous message
Cheers, Jörg
Re: Moving Mylyn task data to new workspace [message #596974 is a reply to message #67146] Fri, 20 March 2009 12:54 Go to previous message
> Cheers, Jörg
Jonathan
Re: Moving Mylyn task data to new workspace [message #596984 is a reply to message #67154] Fri, 20 March 2009 23:10 Go to previous message
Steffen
>> work.
>> Cheers, Jörg
> Jonathan
Steffen Pingel
Previous Topic:Import Repository
Next Topic:Jira Connector
Current Time: Fri Nov 21 04:31:03 EST 2025
Powered by FUDForum. Page generated in 0.04054 seconds
