Home » Language IDEs » AspectJ » How I can weave an aspect inside a .jar from eclipse
How I can weave an aspect inside a .jar from eclipse [message #67130] Thu, 05 October 2006 22:37 Go to next message
Originally posted by: rmilian.estudiantes.uci.cu
that's, the problem is that I can weave an aspect in the concole with the
following command "ajc –injars <..>" but I want to do this from the
eclipse directly.
regards
Re: How I can weave an aspect inside a .jar from eclipse [message #67141 is a reply to message #67130] Fri, 06 October 2006 03:37 Go to previous messageGo to next message
Originally posted by: hawkinsh.uk.ibm.com
In Eclipse you can add jars to the inpath via the project properties pages
(right click on a project > Properties > AspectJ Build > Inpath) or by
right clicking on a project > AspectJ Tools > Configure AspectJ Build Path
> Inpath. There is documentation about this in the "AspectJ Development
User Guide" section of the Eclipse Help system (Help > Help Contents).
Thanks, Helen
Re: How I can weave an aspect inside a .jar from eclipse [message #67169 is a reply to message #67141] Fri, 06 October 2006 10:15 Go to previous message
Helen thank you very much....
Re: How I can weave an aspect inside a .jar from eclipse [message #594920 is a reply to message #67130] Fri, 06 October 2006 03:37 Go to previous message
Thanks, Helen
Re: How I can weave an aspect inside a .jar from eclipse [message #594945 is a reply to message #67141] Fri, 06 October 2006 10:15 Go to previous message
Previous Topic:Why do advice-precedence warnings not go away?
Next Topic:Why do advice-precedence warnings not go away?
Current Time: Sat Aug 23 00:51:42 EDT 2025
Powered by FUDForum. Page generated in 0.03765 seconds
