Home » Language IDEs » AspectJ » How do I apply an aspect using AJDT???
How do I apply an aspect using AJDT??? [message #67103] Thu, 05 October 2006 10:00 Go to next message
Originally posted by: owencorpening.yahoo.com
I have a helloworld in one package and an aspect in another. I have a
build.bat that builds and runs it, and I get the logging I expect from the
aspect. I do "create project from existing source" in eclipse - and none
of the methods in helloworld are advised .... I honestly can't figure out
how to make them "be advised".
Here is the project:
com.howdy.helloworld.java
com.tracing.HelloAspect.aj
This must be simple ... next I will want to just add an aspect jar and
apply it .... I couldn't figure out how to do any of this from watching
the demo's, which is evidently the only documentation on AJDT.
here is the .bat file in case that matters:
set classpath=%classpath%;.
ajc com\howdy\*.java com\tracing\HelloAspect.aj
java com.howdy.HelloWorld
owen
Re: How do I apply an aspect using AJDT??? [message #67113 is a reply to message #67103] Thu, 05 October 2006 10:47 Go to previous messageGo to next message
Hi Owen,
Firstly, there is plenty of documentation for AJDT available in the
Eclipse help system: Help > Help Contents > AspectJ Development User
Guide. (I see this is only available after installing AJDT, not from
the website - I'll look into adding it there).
Building using ajc from a bat file is only really suitable for use
outside eclipse. For use inside Eclipse you need to create an AspectJ
project (or convert a Java project).
Matt.
> the aspect. I do "create project from existing source" in eclipse - and
> none of the methods in helloworld are advised .... I honestly can't
> figure out how to make them "be advised".
> owen
Re: How do I apply an aspect using AJDT??? [message #67121 is a reply to message #67113] Thu, 05 October 2006 13:41 Go to previous message
I hadn't even thought to look in "help" for the docs, I never saw any
reference to any docs elsewhere, thanks.
The fundamental answer seems to have been to add the aspect to the
aspectPath under project properties ...
thanks again,
owen
Matt Chapman wrote:
> Hi Owen,
> Matt.
>> ajc comhowdy*.java comtracingHelloAspect.aj
>> Thanks,
>> owen
Re: How do I apply an aspect using AJDT??? [message #594880 is a reply to message #67103] Thu, 05 October 2006 10:47 Go to previous message
Hi Owen,
Matt.
> owen
Re: How do I apply an aspect using AJDT??? [message #594895 is a reply to message #67113] Thu, 05 October 2006 13:41 Go to previous message
thanks again,
owen
Matt Chapman wrote:
> Hi Owen,
> Matt.
>> Thanks,
>> owen
Previous Topic:How do I apply an aspect using AJDT???
Next Topic:How I can weave an aspect inside a .jar from eclipse
Current Time: Sun Nov 02 21:51:12 EST 2025
Powered by FUDForum. Page generated in 0.07181 seconds
