Home » Language IDEs » C / C++ IDE (CDT) » Debugger doesn't work
Debugger doesn't work [message #67079] Mon, 21 April 2003 13:41 Go to next message
Originally posted by: aricart.smartsoft.com
I have MinGW 3.2 installed with CDT, and I am unable to use the debugger.
When ever the debugger starts, I get
"Exception occurred during launch Reason: Failed Launching CDI Debugger: No
symbol "auto" in current context.
Any ideas what this is and how to solve it?
/a
Re: Debugger doesn't work [message #67097 is a reply to message #67079] Mon, 21 April 2003 14:02 Go to previous messageGo to next message
Never mind.
The debugger needs to be set to MinGW debugger in the Debug TAB. It would be
great if some of these settings could be available from the preferences
area. As for all projects and things that I do with CDT these settings are
very likely to be the same. Perhaps a local setting on the Run/Project tab
can override these settings.
/a
"Alberto Ricart" <aricart@smartsoft.com> wrote in message
news:b819m9$jn1$1@rogue.oti.com...
> Hello,
No
> /a
Re: Debugger doesn't work [message #67107 is a reply to message #67097] Mon, 21 April 2003 14:41 Go to previous message
Originally posted by: mikhailk.qnx.com
Good point. Can you create a change request in bugzilla?
news:b81ash$kp2$1@rogue.oti.com...
> Never mind.
be
> /a
> > Hello,
debugger.
> No
> > Thanks,
> > /a
Previous Topic:Environment variables solution?
Next Topic:Projects with C/C++ and Java
Current Time: Sat Nov 08 19:38:46 EST 2025
Powered by FUDForum. Page generated in 0.03958 seconds
