Home » Newcomers » Newcomers » Multiplatform Installation Issue (Solaris, Linux)
Multiplatform Installation Issue (Solaris, Linux) [message #67032] Fri, 20 May 2005 09:26
Originally posted by: adalbert.perbandt.infineon.com
Hi there,
I'm looking for a smart way to install eclipse 3.1M7 in a network
environment consisting of Sun SPARC machines with Solaris 8 and x86 Linux
machines with RedHat Enterprise Server 3.0. The installation is performed
on a central file server and the file system with the installation is then
mounted readonly on the client machines.
The Eclipse SDK is provided in separate packages for different platforms.
In my case I have to install
on Linux: eclipse-SDK-3.1M7-linux-gtk.tar.gz
and on Solaris: eclipse-SDK-3.1M7-solaris-motif.zip
The problem also exists with some platform dependent plugins like e.g. the
CDT.
In fact a significant part of the software is java and should be platform
independent. But I'm not sure if the platform specific parts are located
in differently named files. My question now is: Is it possible to install
the platform specific eclipse packages on top of each other?
Thanks in advance for any hints.
Adalbert Perbandt.
Previous Topic:how to manually create a plugin (not from eclipse workbench)
Next Topic:How to set an argument to my project
Current Time: Mon Nov 10 15:21:50 EST 2025
Powered by FUDForum. Page generated in 0.08404 seconds
