Home » Language IDEs » AspectJ » AJDT doesn't switch on
AJDT doesn't switch on [message #67031] Mon, 25 September 2006 03:04 Go to next message
Originally posted by: gopi.read-ink.com
I have downloaded the appropriate ajdt
file(ajdt_1.3.2_for_eclipse_3.1.zip) and unzipped it under eclipse
installation directory.
As per the readme, the AJDT must be enabled the next time I start eclipse.
But even after several restarts, AJDT is not avialble on my eclipse. Can
someone please help?
Re: AJDT doesn't switch on [message #67046 is a reply to message #67031] Mon, 25 September 2006 07:04 Go to previous message
> eclipse. But even after several restarts, AJDT is not avialble on my
> eclipse. Can someone please help?
Firstly, please double check you're using Eclipse 3.1.2 (or 3.1.1).
Then check that AJDT was unzipped at the right level - from the
directory containing the eclipse executable, go into the plugins
directory, and make sure there is a JAR file called
org.eclipse.ajdt.core_1.3.2.20060804095248.jar.
Then go to Help > Software Updates > Manage Configuration...
and look for the AspectJ Development Tools feature, and see if that
indicates any problem.
A quick way to see if AJDT is enabled is to look for the "AJ" icon on
the toolbar to create a new AspectJ project.
--Matt
Re: AJDT doesn't switch on [message #594806 is a reply to message #67031] Mon, 25 September 2006 07:04 Go to previous message
--Matt
Previous Topic:AJDT doesn't switch on
Next Topic:the shadow for this join point is not exposed in the structure model?!?
Current Time: Sun Jul 27 12:41:23 EDT 2025
Powered by FUDForum. Page generated in 0.03224 seconds
