| Exception during startup [message #66994] |
Thu, 17 April 2003 04:31 |
Originally posted by: henrikandoffjobbet.hotmail.com
I'd like to run CDT and I'm trying to launch Eclipse
eclipse-SDK-2.0.2-solaris-motif on SunOS 5.8 (Solaris 8) using Java(TM) 2
Runtime Environment, Standard Edition (build 1.3.1_01), Java HotSpot(TM)
Client VM (build 1.3.1_01, mixed mode), but get the following after the
splash screen has appeared:
java.lang.ArrayIndexOutOfBoundsException
at org.eclipse.swt.graphics.ImageData.blit(ImageData.java:2318)
at org.eclipse.swt.graphics.Image.putImage(Image.java:1200)
at org.eclipse.swt.graphics.Image.init(Image.java:988)
at org.eclipse.swt.graphics.Image.<init>(Image.java:446)
org.eclipse.jface.action.ActionContributionItem$ImageCache.g etGrayImage(Acti
onContributionItem.java:105)
org.eclipse.jface.action.ActionContributionItem.updateImages (ActionContribut
ionItem.java:602)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionIte
m.java:468)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.
java:287)
org.eclipse.jface.action.ToolBarManager.update(ToolBarManage r.java:230)
org.eclipse.ui.internal.WorkbenchWindow.addPerspectiveShortc ut(WorkbenchWind
ow.java:295)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1519)
org.eclipse.ui.internal.WorkbenchWindow$7.run(WorkbenchWindo w.java:1235)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:1
222)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:34
5)
org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:932)
org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java:929)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:745)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:581)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1319)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:831)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Any ideas?
Henrik
FUDForum. Page generated in 0.07028 seconds
