Home » Newcomers » Newcomers » Jsp not running on Eclipse3.0
Jsp not running on Eclipse3.0 [message #66991] Fri, 20 May 2005 07:15 Go to next message
Originally posted by: sandip.abc.com
Anybody know why Eclipse could not find the compiler even I installed both
java SDK and JRE? I also set the path corectly. If I try to build it from
the DOS prompt, it comipiled successfully.
The following is error messages:
Unable to find javac compiler....
AND ONE MORE THING HOW CAN I RUN A JSP IN ECLIPSE?
PLS help.
Thanks in advance.
sandip
Re: Jsp not running on Eclipse3.0 [message #67228 is a reply to message #66991] Fri, 20 May 2005 17:29 Go to previous message
Originally posted by: tominospam-eclipse.yahoo.com
Make sure you are using the JDK and not the JRE:
Window > Preferences > Java > Installed JREs
If you see a JRE in the list, then add the JDK.
Hope this helps.
Tomi
> both java SDK and JRE? I also set the path corectly. If I try to build
> it from the DOS prompt, it comipiled successfully.
> PLS help.
> Thanks in advance.
> sandip
Previous Topic:Eclipse CDT Command Line
Next Topic:How to use Images in an Eclipse plugin?
Current Time: Thu Oct 16 17:46:22 EDT 2025
Powered by FUDForum. Page generated in 0.08337 seconds
