Home » Language IDEs » ServerTools (WTP) » Failure while refactoring
Failure while refactoring [message #66964] Fri, 21 January 2005 16:49 Go to next message
Originally posted by: mcfall.verizon.net
I get an error whenever I try to refactor, and I've traced the problem to
the WTP plugin.
Does anyone know how to fix this problem?
A partial stack trace from my log follows.
Greg
STACK TRACE
Root exception:
java.lang.NoSuchFieldError: indexLocations
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.computeIndexLocation(JSPSearchSupport.java:453)
org.eclipse.jst.jsp.core.internal.java.search.JSPPathIndexer $JSPFileVisitor.visit(JSPPathIndexer.java:82)
org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:55)
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:78)
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:82)
org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:116)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:65)
org.eclipse.jst.jsp.core.internal.java.search.JSPPathIndexer .getVisibleJspPaths(JSPPathIndexer.java:101)
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchParti cipant.selectIndexes(JSPSearchParticipant.java:67)
org.eclipse.jdt.internal.core.search.PatternSearchJob.getInd exes(PatternSearchJob.java:80)
org.eclipse.jdt.internal.core.search.PatternSearchJob.ensure ReadyToRun(PatternSearchJob.java:51)
org.eclipse.jdt.internal.core.search.processing.JobManager.p erformConcurrentJob(JobManager.java:170)
org.eclipse.jdt.core.search.SearchEngine.findMatches(SearchE ngine.java:454)
at org.eclipse.jdt.core.search.SearchEngine.search(SearchEngine .java:757)
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt$SearchRunnable.run(JSPSearchSupport.java:207)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1673)Root
exception:
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1673)
Re: Failure while refactoring [message #66983 is a reply to message #66964] Fri, 21 January 2005 17:00 Go to previous message
Originally posted by: pavery.us.ibm.com
WTP M2 must be used with Eclipse 3.1M4 to work correctly.
I believe this same problem has been discussed in previous posts.
-phil
> to the WTP plugin.
> Greg
> STACK TRACE
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:The xml editor recognizes a single an end tag as valid xml
Next Topic:content assist in wt m2
Current Time: Sat Nov 08 19:57:54 EST 2025
Powered by FUDForum. Page generated in 0.02788 seconds
