Home » Language IDEs » ServerTools (WTP) » m4 work with webtools?
m4 work with webtools? [message #66920] Fri, 21 January 2005 10:36 Go to next message
Originally posted by: emerson.tre-sc.gov.br
I installed wtp m2 with eclipse m4, all works, as sql and jsp editing,
except the wizards to create a web project, so i can't do anything.
Is this the expected behaviour? was m4 expected to work with the last wtp?
thanks
Emeson
Re: m4 work with webtools? [message #66939 is a reply to message #66920] Fri, 21 January 2005 13:30 Go to previous message
Hi Emeson,
WTP milestone M2 requires Eclipse 3.1 M4 and the Web project wizards are
working correctly in my installation. Sounds like there is something wrong
with your specific install. Have you tried installing again? What OS are
you using?
Lawrence
wtp?
>thanks
>Emeson
Previous Topic:Server Explorer - MySQL
Next Topic:The xml editor recognizes a single an end tag as valid xml
Current Time: Fri Nov 07 16:33:50 EST 2025
Powered by FUDForum. Page generated in 0.04051 seconds
