Re: how to hide/show/enable/disable a toolbar ? [message #81221 is a reply to message #81206] |
Mon, 27 June 2005 15:58  |
Originally posted by: kpetrov.ics.uci.edu
Hendrik Maryns wrote:
>>> Assume I have 3 plugin which contribute 3 toolbars. How do I
>>> hide/show/enable/disable each plugin ?
>> did anybody figure out the answer?
> Right-click on the toolbar, choose Customize perspective. You can
> change a lot of the buttons and stuff there, don't know how exactly it
> works though. I think your answer is in there somewhere...
the problem is that I can remove a toolbar only together with the
corresponding menu option which I don't want to do.
The other problem is that some of the toolbars that I see don't even
show under the Customize Perspective/Commands tab. So, this is not very
helpful. Could it be because the plugin was written poorly?
Kirill
FUDForum. Page generated in 0.09707 seconds
