| "Scalable" GraphicalRootEditPart and dragging feedback [message #66894] |
Thu, 27 February 2003 21:46  |
I created a ScaleFreeformGraphicalRootEditPart to support "Scalable" graph.
The difference from FreeformGraphicalRootEditPart exists in createFigure().
I changed the HelloGef6 to take it as root EditPart and set the zoom factor
to be "0.7". It works pretty well, except that when I dragging the graph
node, the feedback has a little problem, please see the jpg.jpg attached.
It doesn't happen when I set the zoomfactor to be "2.0". Any suggestion to
resolve the problem?
------------ScaleFreeformGraphicalRootEditPart.java--------- -----------
public class ScaleFreeformGraphicalRootEditPart
extends AbstractGraphicalEditPart
implements RootEditPart, LayerConstants, LayerManager
protected EditPart contents;
protected EditPartViewer viewer;
private LayeredPane innerLayers;
private LayeredPane printableLayers;
protected void createEditPolicies(){}
protected IFigure createFigure() {
FreeformViewport viewport = new FreeformViewport();
innerLayers = new ScalableFreeformLayeredPane();
// difference
((ScalableFreeformLayeredPane)innerLayers).setZoom(0.7);
// difference
createLayers(innerLayers);
viewport.setContents(innerLayers);
return viewport;
protected void createLayers(LayeredPane layeredPane) {
layeredPane.add(getPrintableLayers(), PRINTABLE_LAYERS);
layeredPane.add(new FreeformLayer(), HANDLE_LAYER);
layeredPane.add(new FeedbackLayer(), FEEDBACK_LAYER);
protected LayeredPane createPrintableLayers() {
FreeformLayeredPane layeredPane = new FreeformLayeredPane();
layeredPane.add(new FreeformLayer(), PRIMARY_LAYER);
layeredPane.add(new ConnectionLayer(), CONNECTION_LAYER);
return layeredPane;
* Doesnt provide any command support, returns an
* un-executable command
public Command getCommand(Request req){
return UnexecutableCommand.INSTANCE;
* Returns the figure to which childrens' figures will be added.
* An example would be a ScrollPane. Figures of child editpart are not
* added to the ScrollPane, but to its ViewPort's View.
public IFigure getContentPane(){
return getLayer(PRIMARY_LAYER);
public EditPart getContents(){
return contents;
* Return a drag tracker suitable for dragging this.
public DragTracker getDragTracker(Request req) {
// The drawing cannot be dragged.
return new MarqueeDragTracker();
* Returns the layer for the given key
public IFigure getLayer(Object key){
if (innerLayers == null)
return null;
IFigure layer = innerLayers.getLayer(key);
if (layer != null)
return layer;
if (printableLayers == null)
return null;
return printableLayers.getLayer(key);
* Returns the model of this EditPart.
public Object getModel(){
return LayerManager.ID;
protected LayeredPane getPrintableLayers() {
printableLayers = createPrintableLayers();
return printableLayers;
* defined on interface
public RootEditPart getRoot() {return this;}
* from RootEditPart
public EditPartViewer getViewer() {return viewer;}
protected void refreshChildren(){}
* Sets the contents. The root contains a single child, it's contents.
public void setContents(EditPart editpart){
if (contents != null)
removeChild(contents);
contents = editpart;
addChild(contents,0);
* Sets the viewer.
* @param viewer EditPartViewer.
public void setViewer(EditPartViewer newViewer) {
if (viewer == newViewer)
return;
if (viewer != null)
unregister();
viewer = newViewer;
if (viewer != null)
register();
class FeedbackLayer
extends FreeformLayer
FeedbackLayer() {
setEnabled(false);
Attachment: jpg.jpg
(Size: 76.11KB, Downloaded 102 times)
| Re: "Scalable" GraphicalRootEditPart and dragging feedback [message #67711 is a reply to message #66894] |
Mon, 03 March 2003 00:00   |
Are you using the latest code? What you are seeing looks like a problem
that used to be in FreeformHelper/ScalableFreeformLayeredPane.
There is already a ScalableFreeformGraphicalRootEditPart. Maybe you can use
this class. Maybe you can suggest a better name too! I don't like having 6
words in a class name.
"folklayer" <folklayer@hotmail.com> wrote in message
news:b3mgr2$h97$1@rogue.oti.com...
graph.
createFigure().
factor
> // difference
> // difference
> return viewport;
> return layeredPane;
> return contents;
> return null;
> if (layer != null)
> return layer;
> return null;
> * from RootEditPart
> * Sets the viewer.
> return;
> if (viewer != null)
> unregister();
> viewer = newViewer;
> if (viewer != null)
> register();
> class FeedbackLayer
> FeedbackLayer() {
> setEnabled(false);
FUDForum. Page generated in 0.03548 seconds
