Home » Language IDEs » AspectJ » AspectJ compiler in Eclipse ignores "Includes/Excludes" in source path
AspectJ compiler in Eclipse ignores "Includes/Excludes" in source path [message #66872] Fri, 11 August 2006 11:08 Go to next message
Hi.
I have a project configured in Eclipse which fairly complex source
structure when some parts of the source are preprocessed/generated and
copied to
tmp locations. In Eclipse I have configured the source paths using
"include/exclude" capability. But AspectJ builder still finds two copies
of some java files: one in source folder and other in tmp location and
gives errors about "type is already defined".
Any suggestions?
Eclipse: Version: 3.2.0 Build id: M20060629-1905
AJDT: Version: 1.4.1 Build id: 20060802071129 AspectJ version:
1.5.3.20060801132048
Thank you in advance
Nikita Salnikov-Tarnovski
Re: AspectJ compiler in Eclipse ignores "Includes/Excludes" in source path [message #66892 is a reply to message #66872] Fri, 11 August 2006 11:24 Go to previous message
That version of AJDT should support Java include/excludes (old versions
didn't). Have you tried cleaning the project? Is the tmp location also a
source folder? Could you try reproducing the problem in a test
project? If you can, please raise a bug:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=AJDT
Matt.
Nikita Salnikov-Tarnovski wrote:
> Hi.
> copied to
> Any suggestions?
Re: AspectJ compiler in Eclipse ignores "Includes/Excludes" in source path [message #594649 is a reply to message #66872] Fri, 11 August 2006 11:24 Go to previous message
Matt.
> Hi.
> copied to
> Any suggestions?
Previous Topic:AspectJ compiler in Eclipse ignores "Includes/Excludes" in source path
Next Topic:Eclipse 3.3M1
Current Time: Wed Sep 03 02:24:27 EDT 2025
Powered by FUDForum. Page generated in 0.07193 seconds
