| Display text on Chart [message #66821] |
Thu, 11 August 2005 11:08  |
Originally posted by: statineni.issintl.com
Iam trying on this from long time .
Is there anyway to display some text on chart apart from the Heading and
Y-Series.
Appreicate response.
Sudha
| Re: Display text on Chart [message #67680 is a reply to message #67564] |
Fri, 12 August 2005 04:16   |
Hi Sudha,
The Chart Dialog does not have any functionality to add custom label blocks
to the charts. The only 'fixed' labels you can access are the three titles
(chart title, y axis title, x axis title). The future 2.0 version will also
include a title for the legend.
What kind of label were you planning to add to the chart? If you just want
it besides the chart, then you could use a grid in the report, to layout
your label next to the chart item.
David
"Sudha Tatineni" <statineni@issintl.com> wrote in message
news:d4c3f28da52ef08e0bec32760ba34956$1@www.eclipse.org...
> David,
> Iam not creating it programmatically.
> Iam just trying to find functionality in Chart Dialog which will allow me
> to create a lable in the beside the chart.
> Thanks
> Sudha
> David Michonneau wrote:
>> Sudha,
>> If you are creating you chart programmatically, you should be able to
>> create a new LabelBlock, and add it to the Plot children.
>> Thanks,
>> David
>> news:d8e8590c96e5efd599ba8916896ed238$1@www.eclipse.org...
>>> Hello,
>>> Y-Series.
>>> Thanks
>>> Sudha
| Solved-Re: Display text on Chart [message #68294 is a reply to message #67680] |
Wed, 17 August 2005 12:04  |
David,
It helped.
> Hi Sudha,
> David
>> David,
>> Thanks
>> Sudha
>>> Sudha,
>>> Thanks,
>>> David
>>>> Hello,
>>>> Y-Series.
>>>> Thanks
>>>> Sudha
FUDForum. Page generated in 0.04688 seconds
