Home » Archived » BIRT » Display text on Chart
Display text on Chart [message #66821] Thu, 11 August 2005 11:08 Go to next message
Originally posted by: statineni.issintl.com
Iam trying on this from long time .
Is there anyway to display some text on chart apart from the Heading and
Y-Series.
Appreicate response.
Sudha
Re: Display text on Chart [message #66828 is a reply to message #66821] Thu, 11 August 2005 12:44 Go to previous messageGo to next message
Sudha,
If you are creating you chart programmatically, you should be able to create
a new LabelBlock, and add it to the Plot children.
David
"Sudha Tatineni" <statineni@issintl.com> wrote in message
news:d8e8590c96e5efd599ba8916896ed238$1@www.eclipse.org...
> Hello,
> Y-Series.
> Thanks
> Sudha
Re: Display text on Chart [message #67564 is a reply to message #66828] Thu, 11 August 2005 16:47 Go to previous messageGo to next message
David,
Iam not creating it programmatically.
Iam just trying to find functionality in Chart Dialog which will allow me
to create a lable in the beside the chart.
Sudha
David Michonneau wrote:
> Sudha,
> David
>> Hello,
>> Y-Series.
>> Thanks
>> Sudha
Re: Display text on Chart [message #67680 is a reply to message #67564] Fri, 12 August 2005 04:16 Go to previous messageGo to next message
Hi Sudha,
The Chart Dialog does not have any functionality to add custom label blocks
to the charts. The only 'fixed' labels you can access are the three titles
(chart title, y axis title, x axis title). The future 2.0 version will also
include a title for the legend.
What kind of label were you planning to add to the chart? If you just want
it besides the chart, then you could use a grid in the report, to layout
your label next to the chart item.
David
news:d4c3f28da52ef08e0bec32760ba34956$1@www.eclipse.org...
> David,
> Thanks
> Sudha
>> Sudha,
>> create a new LabelBlock, and add it to the Plot children.
>> Thanks,
>> David
>>> Hello,
>>> Y-Series.
>>> Thanks
>>> Sudha
Solved-Re: Display text on Chart [message #68294 is a reply to message #67680] Wed, 17 August 2005 12:04 Go to previous message
David,
It helped.
> Hi Sudha,
> David
>> David,
>> Thanks
>> Sudha
>>> Sudha,
>>> Thanks,
>>> David
>>>> Hello,
>>>> Y-Series.
>>>> Thanks
>>>> Sudha
Previous Topic:multiple grouping keys on the same series
Next Topic:Problem with setPercent
Current Time: Tue Oct 21 04:50:39 EDT 2025
Powered by FUDForum. Page generated in 0.26217 seconds
