syntax of this ocl expression [message #66799] |
Mon, 09 February 2009 07:34  |
Originally posted by: Sven.T.gmail.com
I want to make sure that the parameters of an UML Operation is the same as
those defined in the UML ParameterNode of an UML Acitivity.
I am using OCL in conjunction with UML2. I attached this OCL constraint to
the UML model.
The context is UML Operation; it's an invariant, written in the body of an
Opaque Expression:
method [0..*] and nodes [0..*] are sets. I wrote the following expression:
ownedParameter = self.method->collect (act |
act.oclIsKindOf(Activity))->select (a | a.node)->select(b |
b.oclIsKindOf(ActivityParameterNode)).Parameter
But the OCL parser won't evaluate this expression. It also shows no error
message so I don't know where the error is actually located.
Hope, someone can help me out.
Sven
Re: syntax of this ocl expression [message #67398 is a reply to message #66799] |
Mon, 09 February 2009 11:27   |
Originally posted by: cdamus.zeligsoft.com
Hi, Sven,
I don't know how you are parsing the expression, in particular what the
context classifier is or what UI component is doing the parsing, but you
can be certain that the OCL parser is producing a more-or-less useful
error message.
Probably the Activity property containing its parameters is not named
"Parameter" but rather "parameter". Another problem is that this
expression iterates all of the methods of the operation, so even if none
of the activities individually have all of the required parameters but
in combination all of the parameters are covered, then the constraint
will pass, though it shouldn't. Finally, I think the ownedParameter
collection is ordered, but the nodes of an activity are not, so the
collections aren't really comparable.
Try this, instead:
self.method->forAll(act | act.oclIsKindOf(Activity) implies
act.oclAsType(Activity).node->select(
oclIsKindOf(ActivityParameterNode))->collect(node |
node.oclAsType(ActivityParameterNode).parameter)->asBag() =
self.owedParameter->asBag())
This ensures that, regardless of ordering, every activity that is a
method of the operation has exactly one parameter node for each
operation parameter, no more and no less (the bag counts replication).
HTH,
Christian
Sven Trehner wrote:
> Hello,
> as those defined in the UML ParameterNode of an UML Acitivity.
> to the UML model.
> an Opaque Expression:
> error message so I don't know where the error is actually located.
> Sven
Re: syntax of this ocl expression [message #67498 is a reply to message #67478] |
Tue, 10 February 2009 09:36  |
Hi, Sven,
Splendid! I'm glad it's working for you.
I guess you see how well I test that OCL snippets that I suggest in this
newsgroup! :-( I promise that I do better testing of the OCL code. :-D
cW
Sven Trehner wrote:
> Hi Christian,
> Comments below:
>> the context classifier is or what UI component is doing the parsing,
>> but you can be certain that the OCL parser is producing a more-or-less
>> useful error message.
> I am using OCL with UML2-codegen. I forgot to insert the Error view in
> my new generated and extended uml2 editor. The error messages are being
> displayed there.
>> Try this, instead:
>> ....node.oclAsType(ActivityParameterNode).parameter)->asBag() =
> I had to insert "n" in ownedParameter but then it worked perfectly !
> Thanks Christian for your explanations and corrected OCL Constraint!
> The OCL constraint is exactly doing what I want.
> Sven
FUDForum. Page generated in 0.47953 seconds
