Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo: AnyTypeEObject class not found
Teneo: AnyTypeEObject class not found [message #66755] Fri, 05 January 2007 09:38 Go to next message
Originally posted by: mat.loo.gmail.com
Hi again,
With the last release (20070401), I have the following problem.
In JPoxDataStore.initialize (line 232), I have a java.lang.ClassNotFound
for org.eclipse.emf.teneo.jpox.mapping.AnyTypeOfEObject (and I guess I
will have the same problem for AnyFeatureMapEntry).
And when I look in the org.eclipse.emf.teneo.jpox plugin, this class is
missing...
Is there a lack in the release ?
Thx
Re: Teneo: AnyTypeEObject class not found [message #66775 is a reply to message #66755] Fri, 05 January 2007 10:35 Go to previous messageGo to next message
In fact, it seems to be the whole org.eclipse.emf.teneo.jpox.enhanced.jar
that is missing...
Re: Teneo: AnyTypeEObject class not found [message #66782 is a reply to message #66775] Fri, 05 January 2007 10:37 Go to previous messageGo to next message
Yes you are right. The packaging of the build went wrong. I am now doing a new build...
gr. Martin
> org.eclipse.emf.teneo.jpox.enhanced.jar that is missing...
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: AnyTypeEObject class not found [message #66824 is a reply to message #66775] Fri, 05 January 2007 15:51 Go to previous message
There is a new latest build in which this should be solved.
gr. Martin
The Netherlands
Re: Teneo: AnyTypeEObject class not found [message #600792 is a reply to message #66755] Fri, 05 January 2007 10:35 Go to previous message
that is missing...
Re: Teneo: AnyTypeEObject class not found [message #600800 is a reply to message #66775] Fri, 05 January 2007 10:37 Go to previous message
gr. Martin
The Netherlands
Re: Teneo: AnyTypeEObject class not found [message #600826 is a reply to message #66775] Fri, 05 January 2007 15:51 Go to previous message
gr. Martin
The Netherlands
Previous Topic:Teneo: AnyTypeEObject class not found
Next Topic:teneo - performance problem with new impl of HibernatePersistableEList.isLoaded()
Current Time: Sun Nov 16 08:33:53 EST 2025
Powered by FUDForum. Page generated in 0.04671 seconds
