Teneo: AnyTypeEObject class not found [message #66755] |
Fri, 05 January 2007 09:38  |
Originally posted by: mat.loo.gmail.com
Hi again,
With the last release (20070401), I have the following problem.
In JPoxDataStore.initialize (line 232), I have a java.lang.ClassNotFound
for org.eclipse.emf.teneo.jpox.mapping.AnyTypeOfEObject (and I guess I
will have the same problem for AnyFeatureMapEntry).
And when I look in the org.eclipse.emf.teneo.jpox plugin, this class is
missing...
Is there a lack in the release ?
Thx
Re: Teneo: AnyTypeEObject class not found [message #66824 is a reply to message #66775] |
Fri, 05 January 2007 15:51  |
There is a new latest build in which this should be solved.
gr. Martin
Mat Lo wrote:
> In fact, it seems to be the whole
> org.eclipse.emf.teneo.jpox.enhanced.jar that is missing...
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: AnyTypeEObject class not found [message #600800 is a reply to message #66775] |
Fri, 05 January 2007 10:37  |
Yes you are right. The packaging of the build went wrong. I am now doing a new build...
gr. Martin
The Netherlands
Re: Teneo: AnyTypeEObject class not found [message #600826 is a reply to message #66775] |
gr. Martin
The Netherlands
FUDForum. Page generated in 0.04501 seconds
