Home » Modeling » BPEL Designer » namespaces in bpel
namespaces in bpel [message #5933] Fri, 08 September 2006 05:08 Go to next message
I'm trying to get all namespaces declared in bpel process, but I
couldn't find any accessor method. When I've finally tried to get underlying
dom element I've got null instead:
if (getProcess().getElement() == null) {
getProcess().updateElement(false);
Element element = getProcess().getElement();
// element == null
Am I doing something wrong?
Rykovanov Dmitri
mailto:drykovan@abisoft.spb.ru
Re: namespaces in bpel [message #6006 is a reply to message #5933] Thu, 28 September 2006 17:00 Go to previous message
Dmitrii,
You probably had figured this by now, but just in case you did not ...
.... the model API does not yet facade the XML DOM, so getElement() will
always return null.
This is one of the things TO DO on the plate.
The place to do get this right now is the BPELResource class in
....model.resource.BPELResource
-michal
Rykovanov Dmitrii wrote:
> // element == null
> Rykovanov Dmitri
Previous Topic:The very begining fails
Next Topic:Create process from template flashes
Current Time: Wed Nov 26 23:55:14 EST 2025
Powered by FUDForum. Page generated in 0.04650 seconds
