Home » Language IDEs » C / C++ IDE (CDT) » Missing Symbol Table ( newbie question )
Missing Symbol Table ( newbie question ) [message #66702] Fri, 11 April 2003 11:45 Go to next message
Originally posted by: sandro_de_santis.it.ibm.com
I am having great fun with Eclipse, CDT and CGYWIN on Win2K.
I downloaded the latest stable versions about 15 days ago.
Even though my experience is really limited I could compile and run a
simple project.
I wrote the following .mak
Prj1 : Prog1.o
gcc -O Prj1 Prog1.o
Prog1.o : Prog1.c
gcc -ggdb -O Prog1.c
all :
make -f prog1.mak
..PHONY : clean
clean :
-del Prj1.exe -del *.o
the project is compiled and runs correctly in native mode.
When I try to debug it I can stop the execution at the main()
but when I look at the gdb console I get the following:
info threads
No stack.
No symbol table is loaded. Use the "file" command.
info threads
2 thread 1412.0x9d4 * 1 thread 1412.0x588
I'd appreciate any help.
Thank in advance
Sandro
Re: Missing Symbol Table ( newbie question ) [message #66725 is a reply to message #66702] Fri, 11 April 2003 11:59 Go to previous messageGo to next message
I forgot to say that in these conditions Breakpoints do not work, nor
the program runs step by step. It simply keeps running in the gdb window
up to the completion.
Thank you,
Ciao
Sandro
Sandro De Santis wrote:
> Hello,
> simple project.
> Prj1 : Prog1.o
> gcc -O Prj1 Prog1.o
> Prog1.o : Prog1.c
> all :
> make -f prog1.mak
> .PHONY : clean
> clean :
> info threads
> No stack.
> info threads
> Thank in advance
> Sandro
Re: Missing Symbol Table ( newbie question ) [message #66744 is a reply to message #66725] Fri, 11 April 2003 12:58 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Use '-o' instead of '-O' in your make file.
"Sandro De Santis" <sandro_de_santis@it.ibm.com> wrote in message
news:3E96E646.3000008@it.ibm.com...
> Thank you,
> Ciao
> Sandro
> > Hello,
> > simple project.
> > Prj1 : Prog1.o
> > gcc -O Prj1 Prog1.o
> > Prog1.o : Prog1.c
> > all :
> > make -f prog1.mak
> > .PHONY : clean
> > clean :
> > info threads
> > No stack.
> > info threads
> > Thank in advance
> > Sandro
Re: Missing Symbol Table ( newbie question ) [message #66762 is a reply to message #66744] Fri, 11 April 2003 15:43 Go to previous messageGo to next message
Thank you Mikhail for the quick response!!
I did as suggested but unfortunately there are no changes.
Now the gdb console shows the following:
info threads
No stack.
info threads
2 thread 2472.0x9bc * 1 thread 2472.0x8b4 No symbol table is
Single stepping until exit from function main,
which has no line number information.
while the program is still running in suspended mode.
Thank you for your patience!!
Ciao
Sandro
>>Thank you,
>>Ciao
>>Sandro
>>>Hello,
>>>simple project.
>>>Prj1 : Prog1.o
>>> gcc -O Prj1 Prog1.o
>>>Prog1.o : Prog1.c
>>>all :
>>> make -f prog1.mak
>>>.PHONY : clean
>>>clean :
>>>info threads
>>>No stack.
>>>info threads
>>>Thank in advance
>>>Sandro
Re: Missing Symbol Table ( newbie question ) [message #66865 is a reply to message #66762] Fri, 11 April 2003 17:03 Go to previous messageGo to next message
Check if the full path of your executable contains space characters. This is
a bug in this version of CDT but it has been fixed in the head branch.
news:3E971AC5.4070600@it.ibm.com...
> info threads
> No stack.
> info threads
> Ciao
> Sandro
> >>Thank you,
> >>Ciao
> >>Sandro
> >>>Hello,
> >>>simple project.
> >>>Prj1 : Prog1.o
> >>> gcc -O Prj1 Prog1.o
> >>>Prog1.o : Prog1.c
> >>>all :
> >>> make -f prog1.mak
> >>>.PHONY : clean
> >>>clean :
> >>>info threads
> >>>No stack.
> >>>info threads
> >>>Thank in advance
> >>>Sandro
Re: Missing Symbol Table ( newbie question ) [message #66868 is a reply to message #66865] Fri, 11 April 2003 17:13 Go to previous messageGo to next message
Sorry, disregard the previous message.
It seems like your executable doesn't contain debug information. Can you
send your makefile?
"Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
news:b77ach$lrk$1@rogue.oti.com...
is
> > info threads
> > No stack.
> > info threads
> > Ciao
> > Sandro
window
> > >>Thank you,
> > >>Ciao
> > >>Sandro
> > >>>Hello,
> > >>>simple project.
> > >>>Prj1 : Prog1.o
> > >>> gcc -O Prj1 Prog1.o
> > >>>Prog1.o : Prog1.c
> > >>>all :
> > >>> make -f prog1.mak
> > >>>.PHONY : clean
> > >>>clean :
> > >>>info threads
> > >>>No stack.
> > >>>info threads
> > >>>Thank in advance
> > >>>Sandro
Re: Missing Symbol Table ( newbie question ) [message #66875 is a reply to message #66868] Sat, 12 April 2003 07:35 Go to previous messageGo to next message
Mikhail, please forgive me as I sent some misleading info.
First this is my current makefile:
Prj1 : Prog1.o
gcc -o Prj1 Prog1.o
Prog1.o : Prog1.c
gcc -ggdb -o Prog1.c
all :
make -f prog1.mak
..PHONY : clean
clean :
When I started this thread I used the -O and I could get a clean build
but I was missing debugging info.
Then you suggested to use -o I did it and I tried again, but I didn't
build correctly the project again, so in fact the second time I used the
very first build.
Whne I deleted .o and .exe and rebuilt with -o I didn't get a clean
build and the messages I get are as follows:
***(all) Error 2
***(Prog1.o) Error 1
Maybe the installation of CGYWIN is not correct but I don't know how to
go further.
Thank you again,
Ciao
Sandro
> send your makefile?
> is
>>>info threads
>>>No stack.
>>>info threads
>>>Ciao
>>>Sandro
> window
>>>>>Thank you,
>>>>>Ciao
>>>>>Sandro
>>>>>>Hello,
>>>>>>simple project.
>>>>>>Prj1 : Prog1.o
>>>>>> gcc -O Prj1 Prog1.o
>>>>>>Prog1.o : Prog1.c
>>>>>>all :
>>>>>> make -f prog1.mak
>>>>>>.PHONY : clean
>>>>>>clean :
>>>>>>info threads
>>>>>>No stack.
>>>>>>info threads
>>>>>>Thank in advance
>>>>>>Sandro
Re: Missing Symbol Table ( newbie question ) [message #66880 is a reply to message #66702] Sat, 12 April 2003 22:33 Go to previous messageGo to next message
Your Makefile is awefully filled with mistakes!
* -O is for optimizations --> -o <file> is for "output into <file>"
* your target Prj is missing an extension! in you clean rule you wrote
it right
* The first target in you Makefile is 'Prj1', and your 'all' rules is
way below and looks really useless, since Eclipse calls the build
process this way:
make clean
make
Here is a more proper Makefile:
# Makefile for compiling simple projects
# depends on GNU Make and other GNU Tools
# Henning Riedel
# set your programs here and add neccesary object-files here
TargetArch = Windows
ifeq ($(TargetArch),"Windows")
EXE_EXTENSION = .exe
LIB_EXTENSION = .lib
elsis ($(TargetArch),"Unix")
EXE_EXTENSION =
LIB_EXTENSION = .a
endif
PROG1 = myprog$(EXE_EXTENSION)
PROG1_OBJ = myprog.o extramodule.o
PROG2 = anotherprog$(EXE_EXTENSION)
PROG2_OBJ = anotherprog.o othermodule.o
LIB1 = mylibrary$(LIB_EXTENSION)
LIB1_OBJ = module.o module2.o module3.o
CLEANFILES = $(PROG1) $(PROG1_OBJ)
CLEANFILES += $(PROG2) $(PROG2_OBJ)
CLEANFILES += $(LIB1) $(LIB1_OBJ)
# setup some needed tools and their flags and some include/library-paths
CC = gcc
AR = ar
RM = -rm -f
# for windows you could use
#RM = -del
# actually gdb is most likely the default debugger
# though -g would be good too
C_DEBUG = -ggdb
CFLAGS = $(C_DEBUG) -I<extraincludedirs>
LDFLAGS = -L<extralibs_dirpath> -lc
# these targets are no real files!
..PHONY: all debug clean
# the default target, if make is being called _without_ target
..DEFAULT: all
# if target 'all' is set, clear C_DEBUG
all:
$(MAKE) "C_DEBUG=" $(PROG1) $(PROG2) $(LIB1)
debug:
$(MAKE) $(PROG1) $(PROG2) $(LIB1)
$(PROG1): $(PROG1_OBJ)
$(CC) -o $@ $< $(LDFLAGS)
# rule for building PROG2
$(PROG2): $(PROG2_OBJ)
# rule for building a static library
# actually build all LIB1_OBJ-files before by calling the %o:-rule
# and then more or less copy them into the .a file
$(LIB1): $(LIB_OBJ)
$(AR) cr $@ $<
# general rule for compiling C-Files to objects
%.o: %.c
$(CC) $(CFLAGS) -o $@ -c $^
# general rule for compiling C++-Files to objects
%.o: %.cpp
$(CXX) $(CXXFLAGS) -o $@ -c $^
clean:
$(RM) $(CLEANFILES)
#### add dependencies below and if one of these file in the deps
#### is changed, compile the files again
myprog.o: myprog.c myprog.h extramodule.h
anotherprog.o: anothermodule.c anothermodule.h othermodule.h
extramodule.o: extramodule.c extramodule.h
othermodule.o: othermodule.c othermodule.h
module1.o: module1.c module1.h
module2.o: module2.c module2h
module3.o: module3.c module3.h
################### Makefile End #######################################
I have pasted a Makefile here before which also checks MAKECMDGLOBALS if
make is called with 'debug' to either set C_DEBUG or not.
kesselhaus
Sandro De Santis schrieb:
> Hello,
> simple project.
> Prj1 : Prog1.o
> gcc -O Prj1 Prog1.o
> Prog1.o : Prog1.c
> all :
> make -f prog1.mak
> .PHONY : clean
> clean :
> info threads
> No stack.
> info threads
> Thank in advance
> Sandro
Re: Missing Symbol Table ( newbie question ) [message #66915 is a reply to message #66880] Mon, 14 April 2003 11:22 Go to previous messageGo to next message
Thank you!!!
I modified your makefile and could consistently build my test program.
Unfortunately I still cannot run the program step by step nor
stop at breakpoints.
I did also the following:
- copied the files ( .c and .mak ) into the native cygwin environment
- built the program again
- compared the size of the .exes : they are the same.
- then I rebuilt ( in cygwin ) the program WITHOUT the -g or -ggdb
options and THE SIZE REMAINS THE SAME!!!
No Debugging info are added in either cases.
So, it looks like a problem in cygwin.
I subscribed to the cygwin@cygwin.com but I have problems because my
e-mails are rejected.
I'll try anyway to reach that mailing list.
Thanks to all for the helpful info.
ciao
Sandro
> it right
> process this way:
> make clean
> make
> # Henning Riedel
> EXE_EXTENSION =
> LIB_EXTENSION = .a
> endif
> CC = gcc
> AR = ar
> RM = -rm -f
> #RM = -del
> C_DEBUG = -ggdb
> .DEFAULT: all
> all:
> debug:
> $(LIB1): $(LIB_OBJ)
> $(AR) cr $@ $<
> %.o: %.c
> %.o: %.cpp
> clean:
> $(RM) $(CLEANFILES)
> kesselhaus
>> Hello,
>> simple project.
>> Prj1 : Prog1.o
>> gcc -O Prj1 Prog1.o
>> Prog1.o : Prog1.c
>> all :
>> make -f prog1.mak
>> .PHONY : clean
>> clean :
>> info threads
>> No stack.
>> info threads
>> Thank in advance
>> Sandro
Re: Missing Symbol Table ( newbie question ) [message #66942 is a reply to message #66915] Tue, 15 April 2003 12:37 Go to previous messageGo to next message
The first is by myself :(
In the top ifeq... the elsis must be written as:
else
ifeq ($(TargetArch),"Unix")
endif
endif
since make does not recognize nested conditional statements.
The second mistake is yours.
In the debug: -rule, their is no "C_DEBUG=", since this would clear out
this variable!
Thats why I added it just in the 'all'-rule, where you dont want debug
infos usually.
The make command in the debug-rule should be:
<tab>$(MAKE) $(PROG1)
Also, if you set .DEFAULT: debug, you dont need to move the debug rule
above the all-rule.
kesselhaus
> Thank you!!!
> ciao
> Sandro
>> it right
>> process this way:
>> make clean
>> make
>> # Henning Riedel
>> EXE_EXTENSION =
>> LIB_EXTENSION = .a
>> endif
>> CC = gcc
>> AR = ar
>> RM = -rm -f
>> #RM = -del
>> C_DEBUG = -ggdb
>> .DEFAULT: all
>> all:
>> debug:
>> $(LIB1): $(LIB_OBJ)
>> $(AR) cr $@ $<
>> %.o: %.c
>> %.o: %.cpp
>> clean:
>> $(RM) $(CLEANFILES)
>> kesselhaus
>>> Hello,
>>> simple project.
>>> Prj1 : Prog1.o
>>> gcc -O Prj1 Prog1.o
>>> Prog1.o : Prog1.c
>>> all :
>>> make -f prog1.mak
>>> .PHONY : clean
>>> clean :
>>> info threads
>>> No stack.
>>> info threads
>>> Thank in advance
>>> Sandro
Re: Missing Symbol Table ( newbie question ) [message #67012 is a reply to message #66702] Thu, 17 April 2003 11:13 Go to previous message
Originally posted by: brianr1026.netscape.net
Regardless of the details of your makefile, if you can build and run from
the Cygwin shell, but get
> info threads
when you try to debug within CDT, it is because there are spaces in the
path to your project. Move the project to a path without spaces, or move
the entier Eclipse install to a path without spaces and it should work. I
was tearing my hair out over the same problem.
Brian
> Hello,
> simple project.
> Prj1 : Prog1.o
> gcc -O Prj1 Prog1.o
> Prog1.o : Prog1.c
> all :
> make -f prog1.mak
> ..PHONY : clean
> clean :
> info threads
> No stack.
> info threads
> Thank in advance
> Sandro
Previous Topic:pasting into folders in C/C++ Projects view
Next Topic:CDT Debugger won't initialize...
Current Time: Sun Nov 23 01:34:41 EST 2025
Powered by FUDForum. Page generated in 0.05891 seconds
