Home » Archived » XML Schema Definition (XSD) » extension base
| extension base [message #66641] |
Fri, 17 March 2006 08:40  |
I am new to this group and XSD.
I have gone through news group and understand that to resolve extension
base elements we should use GetContentType(). But I was not able to
resolve.
Can any one please share me code snipped to resolve the below schema.
Advance Thanks
Param.
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:complexType name="Address">
<xs:sequence>
<xs:element name="name" type="xs:string"/>
<xs:element name="street" type="xs:string"/>
<xs:element name="city" type="xs:string"/>
</xs:sequence>
<xs:attribute name="Person" type="xs:string"/>
</xs:complexType>
<xs:complexType name="USAddress">
<xs:complexContent>
<xs:extension base="Address">
<xs:sequence>
<xs:element name="state" type="xs:string"/>
<xs:element name="zip" type="xs:string"/>
</xs:sequence>
<xs:attribute name="Surname" type="xs:string"/>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:complexType name="NYAddress">
<xs:complexContent>
<xs:extension base="USAddress">
<xs:attribute name="RentControlled" type="xs:boolean"/>
</xs:extension>
</xs:complexType>
<xs:element name="address" type="NYAddress"/>
</xs:schema>
| Re: extension base [message #66730 is a reply to message #66667] |
Mon, 20 March 2006 11:40   |
Hi Ed Merks,
Thanks for your support.
I have used XSDComplexTypeDefinition.getContentType() to get resolved
elements from imported/included schema files.
I have created standalone java class file which will resolve elements and
prints their names in tree format for your reference.
The problem with current code is it is not able to resolve element
'oa:Parties' defination the xpath for this element is Parties
/ProcessRemittanceAdvice/DataArea/RemittanceAdvice/Header/Pa rties
From this element onwards it is going to infinite loop.
sorry for my english. here are the code and sample files I have used.
Advance Thanks
Param
Java Class (XSDParserStandAlone.java):
* Created on Mar 9, 2005
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
package com.gxs.ai.ngwb.xsdparser;
import java.io.File;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Iterator;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xsd.XSDAttributeDeclaration;
import org.eclipse.xsd.XSDAttributeGroupContent;
import org.eclipse.xsd.XSDAttributeGroupDefinition;
import org.eclipse.xsd.XSDAttributeUse;
import org.eclipse.xsd.XSDComplexTypeContent;
import org.eclipse.xsd.XSDComplexTypeDefinition;
import org.eclipse.xsd.XSDDiagnostic;
import org.eclipse.xsd.XSDElementDeclaration;
import org.eclipse.xsd.XSDModelGroup;
import org.eclipse.xsd.XSDModelGroupDefinition;
import org.eclipse.xsd.XSDParticle;
import org.eclipse.xsd.XSDParticleContent;
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.XSDSchemaContent;
import org.eclipse.xsd.XSDSimpleTypeDefinition;
import org.eclipse.xsd.XSDTypeDefinition;
import org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl;
import org.eclipse.xsd.impl.XSDElementDeclarationImpl;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
import org.eclipse.xsd.util.XSDResourceImpl;
* @author tatinip
* TODO To change the template for this generated type comment go to
public class XSDParserStandAlone
private String m_rootElementName;
private boolean m_isRoot = false;
private boolean m_ignoreCpexTypeDefnName = false;
public XSDParserStandAlone(){
public boolean parseXSD(String xsdFileName ,
String rootElementName)
throws FileNotFoundException , IOException , Exception
m_rootElementName = rootElementName;
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl()); //$NON-NLS-1$
try
boolean status = validateAndProcess(xsdFileName);
return status;
}catch(IOException ioe)
throw ioe;
}catch(Exception e)
throw e;
private boolean validateAndProcess(String xsdFile) throws Exception
* This let's us test whether the string exists as a file.
* It not, we try as a URI.
ArrayList retVal = new ArrayList();
URI uri;
if (xsdFile==null ){
//DMParseError parserError = new DMParseError(4,"","Schema file not
specified",0,0);
//m_error_List.add(parserError);
//this.rootNode = null;
return true;
File file = new File(xsdFile);
if (!file.exists()){
//DMParseError parserError = new DMParseError(4,"","File Not
Found",0,0);
return true;
if (file.isFile())
uri = URI.createFileURI(file.getCanonicalFile().toString());
else
uri = URI.createURI(xsdFile);
// Create a resource set, create a schema resource, and load the main
schema file into it.
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
XSDResourceImpl xsdMainResource =
(XSDResourceImpl)resourceSet.createResource(URI.createURI("*.xsd "));
//$NON-NLS-1$
xsdMainResource.setURI(uri);
xsdMainResource.load(resourceSet.getLoadOptions());
// Get the first resource, i.e., the main resource and those that
have been included or imported.
Object resource = resourceSet.getResources().get(0);
if (resource instanceof XSDResourceImpl)
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
XSDSchema xsdSchema = xsdResource.getSchema();
xsdSchema.validate();
* Schema file is valid if Diagnostics is empty
if (!xsdSchema.getAllDiagnostics().isEmpty())
for (Iterator i = xsdSchema.getAllDiagnostics().iterator();
i.hasNext(); )
XSDDiagnostic xsdDiagnostic = (XSDDiagnostic)i.next();
xsdDiagnostic.getLocation();
// print errors here
xsdResource.unload();
return false;
// If the user not selected root element set first element as
root element
if (m_rootElementName == null ||
m_rootElementName.equalsIgnoreCase("")){ //$NON-NLS-1$
Iterator i = xsdSchema.getContents().iterator();
while(i.hasNext()){
XSDSchemaContent e = (XSDSchemaContent)i.next(); // probable root
element
if (e instanceof XSDElementDeclaration){
m_rootElementName = e.getElement().getAttribute("name");
//$NON-NLS-1$
break;
processRoot(xsdSchema);
return true;
return false;
private void processRoot(XSDSchema schema)
//process each element directly under the 'schema' element
for(Iterator i = schema.getElementDeclarations().iterator();
i.hasNext(); )
XSDElementDeclaration e = (XSDElementDeclaration)i.next(); // probable
root element
m_isRoot = true;
if (m_rootElementName != null &&
!m_rootElementName.equalsIgnoreCase("")){ //$NON-NLS-1$
if (m_rootElementName.equalsIgnoreCase(e.getName())){
dumpContentItem(e, 0,"" , ""); //$NON-NLS-1$
break;
}else{
dumpContentItem(e, 0,"", ""); //$NON-NLS-1$
* Method dumpContentItem.
* @param item
* @param level
* This is a recursive method called for handling (currently)
XSDElementDeclaration,
* XSDComplexTypeDefinition, XSDSimpleTypeDefinition,
XSDAttributeDeclaration,
* XSDModelGroupDefinition, XSDAttributeGroupDefinition
private void dumpContentItem(XSDSchemaContent item, int level, String
xPath , String xPathwithTNS)
try{
if(item instanceof XSDElementDeclaration)
XSDElementDeclarationImpl elem = (XSDElementDeclarationImpl)item;
if(elem.getName() != null)
if(xPath.startsWith("/")) //$NON-NLS-1$
xPath = xPath+"/"+elem.getName(); //$NON-NLS-1$
xPathwithTNS = xPathwithTNS + "/" + elem.getQName();
else
// For the root element
System.out.println(xPath);
m_isRoot = false; // Need to do this after writing the root header,
//because the processing of child elements starts here
// Get the type definition of the Element
XSDTypeDefinition elemTypeDef= elem.getTypeDefinition();
if(elemTypeDef==null &&
elem.getResolvedElementDeclaration().getValue() == null)
// For a reference
dumpContentItem(elem.getResolvedElementDeclaration(), level, xPath ,
xPathwithTNS);
}else if((elemTypeDef instanceof XSDSimpleTypeDefinition) &&
((XSDSimpleTypeDefinition)elem.getTypeDefinition()).getConte nts().isEmpty())
// Element doesn't have any children i.e simpleContent but might have
restrictions etc
else // The 'type' attribute is another element in the same XSD file
/* name of the Complex type must be ignored when an element refers to
* it with the 'type' attribute
if(elemTypeDef instanceof XSDComplexTypeDefinition)
if(((XSDComplexTypeDefinition)elemTypeDef).getName()!=null )
m_ignoreCpexTypeDefnName = true;
dumpContentItem(elemTypeDef, level, xPath , xPathwithTNS);
else if (item instanceof XSDComplexTypeDefinition)
XSDComplexTypeDefinitionImpl cplex = (XSDComplexTypeDefinitionImpl)item;
if(!m_ignoreCpexTypeDefnName && cplex.getName()!=null)
xPath = xPath+"/"+cplex.getName(); //$NON-NLS-1$
xPathwithTNS = xPathwithTNS + "/" + cplex.getQName();
// Process the attributes
for(Iterator i = cplex.getAttributeUses().iterator(); i.hasNext(); )
XSDAttributeGroupContent att_grp = (XSDAttributeGroupContent) i.next();
// For attribute group
if(att_grp instanceof XSDAttributeGroupDefinition)
dumpContentItem(((XSDAttributeGroupDefinition)att_grp), level, xPath
, xPathwithTNS);
}else if(att_grp instanceof XSDAttributeUse)
dumpContentItem(((XSDAttributeUse)att_grp).getAttributeDecla ration(),level,
else
System.out.println("2. UNHANDLED"); //$NON-NLS-1$
if (cplex.getContentType() != null){
XSDComplexTypeContent cont = cplex.getContentType();
if (cont instanceof XSDParticle)
dumpParticle((XSDParticle)cont,level, xPath , xPathwithTNS);
}else if(cplex.getContent() != null)
if(cplex.getContent() instanceof XSDParticle)
dumpParticle((XSDParticle)cplex.getContent(), level, xPath ,
xPathwithTNS);
else if(cplex.getContent() instanceof XSDSimpleTypeDefinition)
dumpContentItem((XSDSimpleTypeDefinition)cplex.getContent(), level,
else
System.out.println("1. UNHANDLED"+ cplex.getContent().toString());
//$NON-NLS-1$
/*if (cplex.getContentType() != null){
if(cplex.getContentType() instanceof XSDParticle)
dumpParticle((XSDParticle)cplex.getContentType(), level, xPath ,
xPathwithTNS);
else if(cplex.getContentType() instanceof XSDSimpleTypeDefinition)
dumpContentItem((XSDSimpleTypeDefinition)cplex.getContentTyp e(),level,
else
//$NON-NLS-1$
else if (item instanceof XSDSimpleTypeDefinition)
XSDSimpleTypeDefinition simple = (XSDSimpleTypeDefinition)item;
xPath = xPath+"/"+simple.getName(); //$NON-NLS-1$
xPathwithTNS = xPathwithTNS + "/" + simple.getQName() ;
if(simple.getContents() != null )
if(!simple.getContents().isEmpty())
for(Iterator i = simple.getContents().iterator(); i.hasNext(); )
XSDSimpleTypeDefinition child_simple =
(XSDSimpleTypeDefinition)i.next();
dumpContentItem(child_simple, level+1, xPath , xPathwithTNS);
else
System.out.println("4. UNHANDLED"); //$NON-NLS-1$
else
System.out.println("3. UNHANDLED"); //$NON-NLS-1$
else if (item instanceof XSDAttributeDeclaration)
XSDAttributeDeclaration attrib = (XSDAttributeDeclaration)item;
xPath = xPath+"/@"+attrib.getName(); //$NON-NLS-1$
xPathwithTNS = xPathwithTNS + "/@" + attrib.getQName();
} else if(item instanceof XSDModelGroupDefinition)
// For sequence, all, choice
XSDModelGroupDefinition mgdef = (XSDModelGroupDefinition)item;
if(mgdef.getModelGroup() != null)
for(Iterator i = mgdef.getModelGroup().getContents().iterator();
i.hasNext(); )
XSDParticle pcle = (XSDParticle)i.next();
dumpParticle(pcle, level+1, xPath , xPathwithTNS);
} else
// for "<xs:group ref=
dumpContentItem((mgdef.getResolvedModelGroupDefinition()), level,
} else if(item instanceof XSDAttributeGroupDefinition)
XSDAttributeGroupDefinition att_grp = (XSDAttributeGroupDefinition)item;
if(!att_grp.getAttributeUses().isEmpty())
for(Iterator i = att_grp.getAttributeUses().iterator(); i.hasNext(); )
XSDAttributeUse att_use = (XSDAttributeUse)i.next();
dumpContentItem((att_use).getAttributeDeclaration(),level, xPath ,
xPathwithTNS);
}else // For an attributeGroup reference
int k = 0 ;
//dumpContentItem(att_grp.getResolvedAttributeGroupDefinitio n(),
level, xPath);
else
// example : XSDAnnotation, XSDNotationDeclaration, XSDImport,
XSDInclude,
if(item != null)
System.out.println("Unhandled Schema Content : "+ item.toString());
//$NON-NLS-1$
}catch(Exception e)
e.printStackTrace();
// Set the class level helper variables to default values
m_isRoot = false;
* Method dumpParticle.
* @param p
* @param level
private void dumpParticle(XSDParticle p, int level,String xPath , String
xPathwithTNS)
XSDParticleContent partContent= p.getContent();
//XSDComplexTypeDefinition com =
partContent.resolveComplexTypeDefinition(partContent.getElem ent().getNamespaceURI());
if(partContent instanceof XSDSimpleTypeDefinition){
dumpContentItem((XSDSimpleTypeDefinition)partContent, level, xPath ,
xPathwithTNS);
else if(partContent instanceof XSDElementDeclaration)
dumpContentItem((XSDElementDeclaration)partContent, level, xPath ,
xPathwithTNS);
else if(partContent instanceof XSDModelGroupDefinition)
dumpContentItem((XSDModelGroupDefinition)partContent, level, xPath ,
xPathwithTNS);
else if(partContent instanceof XSDModelGroup)
XSDModelGroup temp = (XSDModelGroup)partContent;
for(Iterator i = temp.getParticles().iterator(); i.hasNext(); )
dumpParticle((XSDParticle)i.next(), level+1, xPath , xPathwithTNS);
else
System.out.println("unhandled particle "+ p.toString()); //$NON-NLS-1$
//XSDTerm
//XSDWildcard
public static void main(String args[])
// System.exit(((Integer)new XSDMainExample().run(args)).intValue());
XSDParserStandAlone xp = new XSDParserStandAlone();
try {
xp.parseXSD("ProcessRemittanceAdvice.xsd","ProcessRemittanceAdvice ");
xp.parseXSD("C:\\Trandev501048\\schematest\\Schemas\\NYAddress.xsd ","address");
} catch (Exception e) {
// TODO Auto-generated catch block
Sample XSD files :
1) ProcessRemittanceAdvice.xsd
<!-- edited with XMLSpy v2005 rel. 3 U (http://www.altova.com) by Param
(GXS) -->
xmlns:oa="http://www.openapplications.org/oagis"
xmlns:agilent="http://www.agilent.com/oagis"
targetNamespace="http://www.agilent.com/oagis"
<xs:import namespace="http://www.openapplications.org/oagis"
schemaLocation="RemittanceAdviceTemplate.xsd"/>
<xs:include schemaLocation="RemittanceAdvice.xsd"/>
<xs:element name="ProcessRemittanceAdvice"
type="agilent:ProcessRemittanceAdvice"/>
<xs:complexType name="ProcessRemittanceAdvice">
<xs:complexContent>
<xs:extension base="oa:BusinessObjectDocument">
<xs:sequence>
<xs:element name="DataArea"
type="agilent:ProcessRemittanceAdviceDataArea"/>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:complexType name="ProcessRemittanceAdviceDataArea">
<xs:sequence>
<xs:element ref="agilent:RemittanceAdvice" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
2) RemittanceAdviceTemplate.xsd
(GXS) -->
targetNamespace="http://www.openapplications.org/oagis"
<xs:include schemaLocation="Components_renamed.xsd"/>
</xs:schema>
3) RemittanceAdvice.xsd
(GXS) -->
<xs:element name="Header" type="agilent:RemittanceHeader"/>
<xs:element name="RemittanceAdvice" type="agilent:RemittanceAdvice"/>
<xs:complexType name="PaymentOrder">
<xs:sequence>
<xs:element name="Id" type="xs:string" minOccurs="0"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="RemittanceAdvice">
<xs:sequence>
<xs:element ref="agilent:Header"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="RemittanceHeader">
<xs:sequence>
<xs:element ref="oa:Parties" minOccurs="0"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
4) Meta.xsd
<?xml version="1.0" encoding="utf-8"?>
version="0.02">
<xs:complexType name="BusinessObjectDocument">
<xs:attribute name="revision" use="required">
<xs:simpleType>
<xs:restriction base="xs:string"/>
</xs:simpleType>
</xs:attribute>
</xs:complexType>
<xs:element name="BusinessObjectDocument"
type="oa:BusinessObjectDocument" abstract="true"/>
</xs:schema>
5) Fields_renamed.xsd
(GXS) -->
version="0.02">
<xs:include schemaLocation="Meta.xsd"/>
<xs:complexType name="PartyIdType">
<xs:sequence/>
</xs:complexType>
</xs:schema>
6)Components_renamed.xsd
<xs:include schemaLocation="Fields_renamed.xsd"/>
<xs:element name="Parties" type="oa:Parties">
<xs:annotation>
<xs:documentation
source="http://www.openapplications.org/oagis">Grouping of semantically
named Parties.</xs:documentation>
</xs:annotation>
</xs:element>
<xs:complexType name="Parties" block="extension">
<xs:sequence>
<xs:element ref="oa:PartyType" minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="PartyBase" abstract="true">
<xs:attribute name="active" type="xs:boolean" use="optional"
default="false"/>
<xs:attribute name="oneTime" type="xs:boolean" use="optional"
default="false"/>
</xs:complexType>
<xs:element name="PartyType" type="oa:PartyBase" abstract="true"/>
</xs:schema>
End of Schema files
Thankyou very much
Param
| Re: extension base [message #66764 is a reply to message #66748] |
Tue, 21 March 2006 04:36   |
Hi Ed,
Here is the simplified sample files.
I am running into infinite loop when resolving for Address element
Sample Schema files.
1) NyAddress.xsd
(GXS) -->
xmlns:imp1="http://gxs.com/1" xmlns:imp2="http://gxs.com/2"
<xs:import namespace="http://gxs.com/1" schemaLocation="imp1.xsd"/>
<xs:import namespace="http://gxs.com/2" schemaLocation="imp2.xsd"/>
<xs:complexContent>
<xs:extension base="imp1:USAddress"/>
</xs:complexType>
<xs:element name="address">
<xs:complexType>
<xs:complexContent>
<xs:extension base="NYAddress"/>
</xs:complexType>
</xs:element>
</xs:schema>
---- End of sample XSD------------------------------------
2)imp1.xsd
targetNamespace="http://gxs.com/1" elementFormDefault="qualified"
<xs:complexType name="USAddress" block="extension">
<xs:sequence>
<xs:element ref="imp1:PAddress"/>
</xs:sequence>
</xs:complexType>
<xs:element name="USAddress" type="imp1:USAddress"/>
<xs:element name="PAddress" type="imp1:PAddress"/>
<xs:complexType name="PAddress">
<xs:sequence>
<xs:element name="start" type="xs:string"/>
<xs:element ref="imp2:Address"/>
<xs:element name="end" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
3)imp2.xsd
xmlns:imp2="http://gxs.com/2" targetNamespace="http://gxs.com/2"
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:element name="Address" type="imp2:Address"/>
</xs:schema>
Here is the java code I am using
import org.eclipse.xsd.XSDDiagnosticSeverity;
import sun.reflect.ReflectionFactory.GetReflectionFactoryAction;
* @author tatinip
try
return status;
throw ioe;
}catch(Exception e)
throw e;
URI uri;
specified",0,0);
return true;
Found",0,0);
return true;
if (file.isFile())
else
Boolean.TRUE);
//$NON-NLS-1$
boolean errorFound = false;
i.hasNext(); )
if (xsdDiagnostic.getSeverity().getValue()!=
XSDDiagnosticSeverity.WARNING)
errorFound = true;
if (errorFound){
return false;
root element
while(i.hasNext()){
element
//$NON-NLS-1$
break;
return true;
return false;
i.hasNext(); )
root element
m_isRoot = true;
break;
}else{
* @param item
* @param level
try{
else
xPathwithTNS);
restrictions etc
, xPathwithTNS);
else
xPathwithTNS);
else
//$NON-NLS-1$
}else if (cplex.getContentType() != null){
xPathwithTNS);
else
//$NON-NLS-1$
else
else
i.hasNext(); )
} else
xPathwithTNS);
int k = 0 ;
level, xPath);
else
XSDInclude,
if(item != null)
//$NON-NLS-1$
}catch(Exception e)
m_isRoot = false;
* @param p
* @param level
xPathwithTNS)
xPathwithTNS);
xPathwithTNS);
xPathwithTNS);
for(Iterator i = temp.getContents().iterator(); i.hasNext(); )
XSDParticle part = (XSDParticle)i.next();
dumpParticle(part, level+1, xPath , xPathwithTNS);
else
//XSDTerm
//XSDWildcard
try {
//xp.parseXSD(" C:\\Trandev501048\\schematest\\Schemas\\ProcessRemittanceAdv ice.xsd ","Header");
xp.parseXSD("NYAddress.xsd","address");
Param
| Re: extension base [message #66798 is a reply to message #66764] |
Tue, 21 March 2006 11:57   |
Param,
I don' have time to set up a sample to run it. If you want me to run
something, please zip up the whole self-contained project. I think you
are doing a recursive traversal assuming a tree structure when in fact
you are traversing a graph with cycles.
Param wrote:
> Hi Ed,
> 1) NyAddress.xsd
> Param (GXS) -->
> <xs:complexContent>
> </xs:complexType>
> <xs:complexType>
> <xs:complexContent>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> 2)imp1.xsd
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> 3)imp2.xsd
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> * @author tatinip
> public class XSDParserStandAlone {
> String rootElementName) throws
> try
> return status;
> throw ioe;
> }catch(Exception e)
> { throw e;
> URI uri;
> file not specified",0,0);
> return true;
> Not Found",0,0);
> return true;
> if (file.isFile())
> else
> the main schema file into it.
> Boolean.TRUE);
> //$NON-NLS-1$
> that have been included or imported.
> for (Iterator i =
> xsdSchema.getAllDiagnostics().iterator(); i.hasNext(); )
> errorFound = true;
> if (errorFound){
> return false;
> first element as root element
> while(i.hasNext()){
> // probable root element
> m_rootElementName =
> e.getElement().getAttribute("name"); //$NON-NLS-1$
> break;
> return true;
> return false;
> i.hasNext(); )
> (XSDElementDeclaration)i.next(); // probable root element
> m_isRoot = true;
> break;
> }else{
> * @param item
> * @param level
> String xPath , String xPathwithTNS)
> try{
> else
> root header,
> simpleContent but might have restrictions etc
> same XSD file
> element refers to
> i.hasNext(); )
> dumpContentItem(((XSDAttributeGroupDefinition)att_grp), level, xPath ,
> xPathwithTNS);
> else
> else
> cplex.getContent().toString()); //$NON-NLS-1$
> xPathwithTNS);
> else
> i.hasNext(); )
> xPathwithTNS);
> else
> else
> for(Iterator i =
> mgdef.getModelGroup().getContents().iterator(); i.hasNext(); )
> } else
> for(Iterator i =
> xPathwithTNS);
> int k = 0 ;
> level, xPath);
> else
> XSDImport, XSDInclude,
> if(item != null)
> item.toString()); //$NON-NLS-1$
> }catch(Exception e)
> m_isRoot = false;
> * @param p
> * @param level
> i.hasNext(); )
> else
> //$NON-NLS-1$
> //XSDTerm
> //XSDWildcard
> public static void main(String args[]) {
> try {
> Thanks
> Param
| Re: extension base [message #67374 is a reply to message #67355] |
Wed, 22 March 2006 12:05  |
Param,
As I replied in your direct note, imp1.xsd is missing the required
import of imp2.xsd.
Param wrote:
> Hi Ed Merks,
> I sent a mail to merks@ca.ibm.com with attachment.
> Thanks
> Param
| Re: extension base [message #597797 is a reply to message #66641] |
Fri, 17 March 2006 08:44  |
Param,
Have a look at XSDMainExample.java for how to load the schema properly.
Then if you are stuck, show exactly what you've tried to do.
Param wrote:
> Hi
> extension base elements we should use GetContentType(). But I was not
> able to resolve.
> Advance Thanks
> Param.
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> <xs:complexContent>
> </xs:extension>
> </xs:complexType>
> </xs:schema>
| Re: extension base [message #597814 is a reply to message #66667] |
Hi Ed Merks,
Advance Thanks
Param
* @author tatinip
try
return status;
throw ioe;
}catch(Exception e)
throw e;
URI uri;
specified",0,0);
return true;
Found",0,0);
return true;
if (file.isFile())
else
Boolean.TRUE);
//$NON-NLS-1$
i.hasNext(); )
return false;
root element
while(i.hasNext()){
element
//$NON-NLS-1$
break;
return true;
return false;
i.hasNext(); )
root element
m_isRoot = true;
break;
}else{
* @param item
* @param level
try{
else
// For a reference
xPathwithTNS);
restrictions etc
, xPathwithTNS);
else
xPathwithTNS);
else
//$NON-NLS-1$
xPathwithTNS);
else
//$NON-NLS-1$
else
else
i.hasNext(); )
} else
xPathwithTNS);
int k = 0 ;
level, xPath);
else
XSDInclude,
if(item != null)
//$NON-NLS-1$
}catch(Exception e)
m_isRoot = false;
* @param p
* @param level
xPathwithTNS)
xPathwithTNS);
xPathwithTNS);
xPathwithTNS);
else
//XSDTerm
//XSDWildcard
try {
Sample XSD files :
(GXS) -->
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
(GXS) -->
</xs:schema>
(GXS) -->
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
4) Meta.xsd
version="0.02">
<xs:simpleType>
</xs:simpleType>
</xs:attribute>
</xs:complexType>
</xs:schema>
(GXS) -->
version="0.02">
<xs:sequence/>
</xs:complexType>
</xs:schema>
<xs:annotation>
<xs:documentation
</xs:annotation>
</xs:element>
<xs:sequence>
</xs:sequence>
</xs:complexType>
default="false"/>
default="false"/>
</xs:complexType>
</xs:schema>
End of Schema files
Thankyou very much
Param
| Re: extension base [message #597824 is a reply to message #66748] |
Hi Ed,
1) NyAddress.xsd
(GXS) -->
<xs:complexContent>
</xs:complexType>
<xs:complexType>
<xs:complexContent>
</xs:complexType>
</xs:element>
</xs:schema>
2)imp1.xsd
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
3)imp2.xsd
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
* @author tatinip
try
return status;
throw ioe;
}catch(Exception e)
throw e;
URI uri;
specified",0,0);
return true;
Found",0,0);
return true;
if (file.isFile())
else
Boolean.TRUE);
//$NON-NLS-1$
i.hasNext(); )
errorFound = true;
if (errorFound){
return false;
root element
while(i.hasNext()){
element
//$NON-NLS-1$
break;
return true;
return false;
i.hasNext(); )
root element
m_isRoot = true;
break;
}else{
* @param item
* @param level
try{
else
xPathwithTNS);
restrictions etc
, xPathwithTNS);
else
xPathwithTNS);
else
//$NON-NLS-1$
xPathwithTNS);
else
//$NON-NLS-1$
else
else
i.hasNext(); )
} else
xPathwithTNS);
int k = 0 ;
level, xPath);
else
XSDInclude,
if(item != null)
//$NON-NLS-1$
}catch(Exception e)
m_isRoot = false;
* @param p
* @param level
xPathwithTNS)
xPathwithTNS);
xPathwithTNS);
xPathwithTNS);
else
//XSDTerm
//XSDWildcard
try {
Param
| Re: extension base [message #597835 is a reply to message #66764] |
Param,
Param wrote:
> Hi Ed,
> 1) NyAddress.xsd
> Param (GXS) -->
> <xs:complexContent>
> </xs:complexType>
> <xs:complexType>
> <xs:complexContent>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> 2)imp1.xsd
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> 3)imp2.xsd
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> * @author tatinip
> try
> return status;
> throw ioe;
> }catch(Exception e)
> { throw e;
> URI uri;
> return true;
> Not Found",0,0);
> return true;
> if (file.isFile())
> else
> Boolean.TRUE);
> //$NON-NLS-1$
> for (Iterator i =
> errorFound = true;
> if (errorFound){
> return false;
> while(i.hasNext()){
> m_rootElementName =
> break;
> return true;
> return false;
> i.hasNext(); )
> m_isRoot = true;
> break;
> }else{
> * @param item
> * @param level
> try{
> else
> root header,
> same XSD file
> element refers to
> i.hasNext(); )
> xPathwithTNS);
> else
> else
> xPathwithTNS);
> else
> i.hasNext(); )
> xPathwithTNS);
> else
> else
> for(Iterator i =
> } else
> for(Iterator i =
> xPathwithTNS);
> int k = 0 ;
> level, xPath);
> else
> if(item != null)
> }catch(Exception e)
> m_isRoot = false;
> * @param p
> * @param level
> i.hasNext(); )
> else
> //$NON-NLS-1$
> //XSDTerm
> //XSDWildcard
> try {
> Thanks
> Param
Current Time: Sat Nov 22 13:48:06 EST 2025
Powered by FUDForum. Page generated in 0.10043 seconds
