| How does the AGR work, can we customrize it? [message #66636] | Fri, 14 April 2006 02:12  |  |
| Eclipse User  |  |  |  |  | we are currently planing a test project to automating functional  test our developed eclipse  plugins on linux platform(our plugin must be run on
 linux).
 We have investigate  tools like tptp and rft and others.I used AGR in
 TPTP-4.2.0-200604110100 with eclipe3.2M6 on a redhat linux. It's a amazing
 tool though there are still lot of bugs.
 I have lots of questions on AGR since i can find few document on it.
 Currently AGR can record and play back in linux.(RFT still can's record
 on linux though build on tptp).
 I want to know how does AGR work. Does AGR use something like
 objectmap? When recording,AGR is more fast than RFT.
 when i use AGR to record some customarized SWT UI on a eclipse view.
 AGR can't recongnize the swt ui().(RFT can do this on windows platform).
 I want to know can I  write some extendtion to enable AGR to recongnize
 special  swt ui on eclipse view. If this can be done, how much do i need
 to do?
 Another thing is that I can't found any document about the AGR marco. I
 know what does it mean of my recorded xml fragment.But i don't konw the
 capability of the marco xml(for example does the marco xml support loop?
 if it does, then what's the xml tag? I tried to look  into the soucecode
 of agr and tptp, but it is not easy).
 last is that is there any way to enable the marco to process other
 things currently now support in tptp.Can I add extention to do this? What
 extendtion point do i need to extend?
| Re: How does the AGR work, can we customrize it? [message #66817 is a reply to message #66636] | Mon, 17 April 2006 10:51  |  |
| Eclipse User  |  |  |  |  | Hi Ben,
 I'm not familiar with object maps so I can't confidently answer your
 question.
 AGR registers listeners with the Display object to capture user events.
 > to do?
 There is a feature opened to allow contributors to extend the number of
 commands available:  https://bugs.eclipse.org/bugs/show_bug.cgi?id=110416
 Feel free to add yourself to the CC list and/or vote for the feature.
 I can see from your second post that you have already found the user guide.
 You can add loops in the behavior page of the test suite but you can't add
 it as part of the macro.
 I think I've already answered this one.  Again, see feature
 Thanks for your interest.
 "Ben.Xu" <xufengbing@gmail.com> wrote in message
 news:b5f1f681dee00d7fb98bd6e5a4bddee3$1@www.eclipse.org...
 > linux).
 > to do?
FUDForum. Page generated in 0.44636 seconds
