Home » Eclipse Projects » Eclipse Platform » can't install plugin from update manager
can't install plugin from update manager [message #66603] Sat, 07 June 2003 19:57 Go to next message
Originally posted by: milanst.ptt.yu
I'm trying to install Spindle plugin using Eclipse update manager. When I
point the update manager to http://spindle.sourceforge.net/updates I get the
following error:
Current configuration contains errors that are not corrected with the
requested operation.
When I click for details I get bunch of the following:
Eclipse .... : Feature operating system does not match the enviroment.
How can I fix this?
Milan
Re: can't install plugin from update manager [message #66626 is a reply to message #66603] Sat, 07 June 2003 20:29 Go to previous messageGo to next message
I figured that one out. I removed all the non-win features which were there
because I did the source build.
But now, I cannot add an install location into which I would install my
plugin. There are no install locations available and when I try to add one,
I get the error: The location is not empty (even on empty folders).
What now?
Milan
"Milan Stanojevic" <milanst@ptt.yu> wrote in message
news:bbtu4v$5si$1@rogue.oti.com...
the
> following error:
> How can I fix this?
> Milan
Re: can't install plugin from update manager [message #67771 is a reply to message #66603] Mon, 09 June 2003 07:28 Go to previous message
> following error:
> How can I fix this?
> Milan
Yes that is this bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=35580.
You are probabaly better off take a pre-built eclipse in this case. Or
running the packaging option (if there is such a thing) for the platform
you are on from the build you made. Because eclipse doesn't consider
features as first class objects it is possible to get into a state where
the update manager doesn't function correctly although eclipse seems to
be working because the plugins are loaded. So it requires that eclipse
be *clean* and pure in a feature sense before being able to use the
update manager.
Peter
Previous Topic:What are the eclipse/WSAD 5.0 ant tasks?
Next Topic:How to suppress compile by source and/or project?
Current Time: Sun Jul 13 21:56:56 EDT 2025
Powered by FUDForum. Page generated in 0.05721 seconds
