Home » Eclipse Projects » Mylyn » Reccommend a lightweight issue/bug tracker for personal use...
Reccommend a lightweight issue/bug tracker for personal use... [message #66585] Fri, 13 March 2009 18:57 Go to next message
Originally posted by: sean.hollingsworthinsurance.com
Hello Mylyn folks,
I'm looking for a lightweight task/issue/bug tracker to act as a
personal TO-DO list with Mylyn.
Since I use Eclipse on multiple machines and in multiple configurations
on those machines, the Local Task repository will not do.
I have Bugzilla set up already, but would like to know if there is
something 'lighter' available.
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #66606 is a reply to message #66585] Fri, 13 March 2009 19:07 Go to previous messageGo to next message
Hello Sean
Maybe you should take a look at Mantis [1].
[1] http://www.mantisbt.org/
Yves
[eisfair-team]
"Ich bin nicht sicher, mit welchen Waffen der dritte Weltkrieg
ausgetragen wird, aber im vierten Weltkrieg werden sie mit Stöcken und
Steinen kämpfen."
-- Albert Einstein
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #66627 is a reply to message #66606] Fri, 13 March 2009 19:20 Go to previous messageGo to next message
Originally posted by: gnl.ballroomdancemusic.info
Yves Schumann wrote:
> Hello Sean
Depends on what you mean by 'lighter', but there is the personal version of Jira
as well:
http://www.atlassian.com/software/jira/personal.jsp
George
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #67267 is a reply to message #66585] Thu, 26 March 2009 18:48 Go to previous messageGo to next message
Hi Sean,
You can also try the Industrial SQL Connector and set up your own little
database, like Derby (included) or mySQL (diy)
http://wiki.eclipse.org/Mylyn/Incubator/Generic_SQL_Connecto r
You can have comments and attachments as well.
Maarten Meijer
Sean Adams wrote:
> Hello Mylyn folks,
> Thanks
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #67277 is a reply to message #66585] Fri, 27 March 2009 03:19 Go to previous message
There is free FogBugz available too:
http://www.fogcreek.com/FogBugz/StudentAndStartup.html
No need to setup anything... it is hosted version.
Foglyn connector works fine with it. (Feel free to mail me to get free
Foglyn license for student/startup edition of FogBugz)
-Peter
Sean Adams wrote:
> Hello Mylyn folks,
> Thanks
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #596749 is a reply to message #66585] Fri, 13 March 2009 19:07 Go to previous message
Hello Sean
Yves
[eisfair-team]
Steinen kämpfen."
-- Albert Einstein
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #596757 is a reply to message #66606] Fri, 13 March 2009 19:20 Go to previous message
> Hello Sean
as well:
George
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #597092 is a reply to message #66585] Thu, 26 March 2009 18:48 Go to previous message
Hi Sean,
Maarten Meijer
Sean Adams wrote:
> Hello Mylyn folks,
> Thanks
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #597098 is a reply to message #66585] Fri, 27 March 2009 03:19 Go to previous message
-Peter
Sean Adams wrote:
> Hello Mylyn folks,
> Thanks
Previous Topic:Unable to add "Mylyn Extras" update site
Next Topic:Using subtasks
Current Time: Fri Oct 24 18:03:36 EDT 2025
Powered by FUDForum. Page generated in 0.06120 seconds
