Home » Newcomers » Newcomers » How to set an argument to my project
How to set an argument to my project [message #66513] Thu, 19 May 2005 09:30 Go to next message
Originally posted by: aaa.bbb.com
I'd like to pass an argument into a Java class, how do I config this, do I
have to create a new Builders for the project?
thanks.
Re: How to set an argument to my project [message #66637 is a reply to message #66513] Thu, 19 May 2005 10:01 Go to previous messageGo to next message
You run Java programs in Eclipse using what is called a Launch
Configuration. There are several ways to create a Launch Config, one of
which is to right-click on the class (the one that has a main(String[])
method) and choose Run... from the pop-up menu.
You can also Choose Run > Run... from the main menu bar and create a
Launch Config form scratch.
In either case, there is an Arguments tab for launch configs where you
can specify program arguments.
Also see the Eclipse help for more info on Launch Configurations.
HTH,
Eric
Re: How to set an argument to my project [message #67044 is a reply to message #66637] Fri, 20 May 2005 09:26 Go to previous message
Oh Eric! I can. Thanks a lot.
"Eric Rizzo" <eclipse@rizzoweb.com> wrote in message
news:d6i6aq$u0u$1@news.eclipse.org...
>> I have to create a new Builders for the project?
> In either case, there is an Arguments tab for launch configs where you can
> HTH,
> Eric
Previous Topic:Multiplatform Installation Issue (Solaris, Linux)
Next Topic:Separate Eclipse and Plugins Installation Issue
Current Time: Mon Jul 14 07:21:29 EDT 2025
Powered by FUDForum. Page generated in 0.07869 seconds
