Home » Eclipse Projects » GEF » Problems with HelloGef1
Problems with HelloGef1 [message #66446] Tue, 25 February 2003 04:14 Go to next message
Originally posted by: grandan.tiscali.it
Hi!
I have some problem with the project HelloGef1, and I hope that someone
can help me. I follow the instructions to install the examples but I get
the following errors:
The import org.eclipse.gef.commands.AbstractCommand cannot be
resolved SetConstraintCommand.java HelloGef1/src/org/eclipse/gef/examples/hellogef line
6
Type mismatch: cannot convert from
org.eclipse.gef.examples.hellogef.SetConstraintCommand to
org.eclipse.gef.commands.Command
HelloXYLayoutEditPolicy.java HelloGef1/src/org/eclipse/gef/examples/hellogef line
37 in HelloXYLayoutEditPolicy.createChangeConstraintCommand(EditPa rt,
Object)
Re: Problems with HelloGef1 - problems resolved [message #66467 is a reply to message #66446] Tue, 25 February 2003 06:03 Go to previous message
I solved the problem installing the GEF build I20021122.
> Hi!
> 6
> Object)
Previous Topic:Selection in GEF
Next Topic:Problems with HelloGef2
Current Time: Fri Nov 07 01:20:49 EST 2025
Powered by FUDForum. Page generated in 0.03555 seconds
