Home » Language IDEs » Java Development Tools (JDT) » Subfolders do not appear in the project explorer after creation
Subfolders do not appear in the project explorer after creation [message #66435] Tue, 24 June 2003 16:39 Go to next message
Originally posted by: lebowitz.finaltouch.com
I've written some code to create some file subdirectories. The object is to
create the following:
|_ <project>|
|__WEB-INF|
|__src
|__classes
|__lib
The following snippet is what I'm using...
try {
webFolder = project.getFolder("WEB-INF");
webFolder.create(false, true, null);
if (webFolder.exists()) {
source = webFolder.getFolder("src");
source.create(false, true, null);
source.getParent().refreshLocal(IResource.DEPTH_INFINITE, null);
classes = webFolder.getFolder("classes");
classes.create(false, true, null);
classes.getParent().refreshLocal(
null);
library = webFolder.getFolder("lib");
library.create(false, true, null);
library.getParent().refreshLocal(
null);
The src, classes and lib folders appear correctly on the local file system,
but they never appear in the Java Perspective after they're created. Can
someone indicate why this happens and what I should do to correct the
problem?
Rob
Re: Subfolders do not appear in the project explorer after creation [message #66734 is a reply to message #66435] Wed, 25 June 2003 03:50 Go to previous messageGo to next message
>|_ <project>|
> |__WEB-INF|
> |__src
> |__classes
> |__lib
>problem?
In earlier releases there were problems in the Package Explorer related
to big letters and dashes in the folder name. Do you see the folders in
the Navigator? Do you see the folders in the Java perspective if you
create them via UI (i.e. use File > New)?
Dani
Re: Subfolders do not appear in the project explorer after creation [message #67716 is a reply to message #66734] Wed, 25 June 2003 20:23 Go to previous messageGo to next message
Unfortunately, all of these folder names are in lower case, and none uses
dashes.
Well, sort of. If I try to create the subfolders using the intrinsic
File->New approach, they appear as empty packages within the project tree in
the Java navigator, rather than as subfolders of WEB-INF.
I found this a bit peculiar as well. surely is should be possible to create
folders with subfolders to hold, say, resources?
Rob
Re: Subfolders do not appear in the project explorer after creation [message #67858 is a reply to message #67716] Thu, 26 June 2003 03:25 Go to previous messageGo to next message
>dashes.
So, you say that you misspelled "WEB-INF" and it is actually
"web<something>inf"?
Can you list the exact steps? Are you sure you selected the folder
"WEB-INF" when you created the subfolder?
What about the Navigator related question I asked?
What build version are you using?
Dani
Re: Subfolders do not appear in the project explorer after creation [message #68194 is a reply to message #67858] Thu, 26 June 2003 12:06 Go to previous messageGo to next message
No... sorry... I didn't think about the WEB-INF folder since it appears in
the navigator everytime, I was concerned about the subfolders src, classes
and lib that weren't appearing.
2.1
Last night I made some additions to my code, and lo and behold, the three
missing folders suddenly appeared. Previously the folders were empty, and
simply "folders", but now I set the classes folder as the output location of
the project, and add src as a ClasspathEntry for the project, and the
folders all appeared in the Java navigator.
I still think there is some kind of bug here; the folders should appear in
the navigator without having to specify their other roles, no?
Rob
Re: Subfolders do not appear in the project explorer after creation [message #68555 is a reply to message #68194] Fri, 27 June 2003 03:58 Go to previous message
>2.1
The problem with big letters and dashes in the name has been fixed in 2.1.
It depends. I assume that in your Package Explorer (there is no Java
navigator - at least no in the standard Eclipse SDK) you have a filter
active which filters empty packages ;-)
Dani
Previous Topic:Automatic JAR Creation
Next Topic:JAXP upgrade problem with V3 M1
Current Time: Sun Nov 30 09:20:44 EST 2025
Powered by FUDForum. Page generated in 0.26388 seconds
