| Problems building my updatesite in Galileo [message #66413] |
Wed, 01 July 2009 02:23  |
I want to build my updatesite inside Eclipse Galileo using the contextmenu
on file site.xml, PDE-Tools -> Build site. I get the error:
Could not find one or more classes: "org.apache.tools.ant.BuildException".
Please check the ant classpath.
When I look at Window->Preferences->Ant->Runtime->Classpath there's an
entry showing to ant.jar in the eclipse-installation-path.
Processing an 'jar tvf ant.jar |grep BuildException' I get the result
org/apache/tools/ant/BuildException.class,
so I think it's not a problem, that I miss this class.
What do I need in addition to that to build my updatesite?
Greetings
Markus
| Re: Problems building my updatesite in Galileo [message #68001 is a reply to message #66413] |
Sat, 11 July 2009 14:16  |
Hello
I had a similar problem when upgrading from ganymede to galileo.
The following actions had solved the problem for me (but I don't
understand why):
- go to Window/prefrences/Ant/Runtime
- remove all entries under "Ant Home entries"
- select Add external Jars, navigate to your eclipse installation
directory,
then go inside
"plugins/org.apache.ant_1.7.1.v20090120-1145/lib"
and select all jars inside
I hope it can help you
| Re: Problems building my updatesite in Galileo [message #599295 is a reply to message #66413] |
Hello
understand why):
directory,
then go inside
FUDForum. Page generated in 0.33724 seconds
