Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » XSD -> ECORE conversion : problem with XSD inclusion
XSD -> ECORE conversion : problem with XSD inclusion [message #66406] Thu, 04 January 2007 05:49 Go to next message
Originally posted by: turmeau.laurent.fmtls.siemensvdo.com
I'm creating an EMF project, and the ECORE model is imported from a XML
schema.
This XML schema includes another one like this:
test.xsd
<xs:schema xmlnss="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:include schemaLocation="template_declaration.xsd"/>
<xs:element name="TOTO">
<xs:complexType>
<xs:sequence>
<xs:element ref="TITI_1" minOccurs="0"/>
<xs:element ref="TITI_2" minOccurs="0"/>
</xs:sequence>
<xs:attribute name="Name" use="required">
</xs:attribute>
</xs:complexType>
</xs:element>
</xs:schema>
The ECORE model is generated successfully, but the Root package is
templateDeclaration whereas TOTO is expected.
I tried to avoid this, using ecore directives in the XSD to force the
generated package name. it gives something like this:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
ecore:package="TOTO"
ecore:nsPrefix="TOTO">
Now, a TOTOPackage interface is generated, that defines:
String eNAME = "TOTO";
String eNS_URI =
" file:/C:/DATA/WICO_TLS/CongaConfig/xsd/template_declaration. xsd ";
String eNS_PREFIX = "TOTO";
The URI is not correct: test.xsd is expected. Indeed, when I try to load a
XML resource, EMF tries to map the XML against the
template_declaration.xsd. And it fails.
Has anybody encountered this problem?
regards
Laurent
Re: XSD -> ECORE conversion : problem with XSD inclusion [message #68159 is a reply to message #66406] Tue, 16 January 2007 07:29 Go to previous message
Laurent,
I think you asked this same question on the EMF newsgroup... The
XSDEcoreBuilder processes all the elements and types of a schema in
arbitrary order and hence the first element or type processed for the
null namespace will determine which physical schema location is used as
the nsURI. It's probably best to define your schemas to have a
targetNamespace...
Laurent TURMEAU wrote:
> Hello,
> XML schema.
> test.xsd
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:attribute>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> String eNS_URI =
> load a XML resource, EMF tries to map the XML against the
> regards
> Laurent
Re: XSD -> ECORE conversion : problem with XSD inclusion [message #601262 is a reply to message #66406] Tue, 16 January 2007 07:29 Go to previous message
Laurent,
targetNamespace...
> Hello,
> XML schema.
> test.xsd
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:attribute>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> String eNS_URI =
> regards
> Laurent
Previous Topic:Re: Can EMF Technology "Transaction" Execute Stand-Alone?
Next Topic:How can i set xmi:id in emf?
Current Time: Fri Oct 17 05:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.21779 seconds
