Home » Archived » M2M (model-to-model transformation) » [ATL] Raising transformation errors and "auxiliary" parameters
[ATL] Raising transformation errors and "auxiliary" parameters [message #66367] Mon, 19 November 2007 04:46 Go to next message
Hi.
Is it possible with current ATL to generate errors or exceptions during
transformation, for example to signal a incoherence in the source model
preventing the generation of a correct destination model?
Also, what is the best way to pass ATL parameters to control the
transformation? Currently I'm attaching metadata to the source model.
Thanks.
Lorenzo
Re: [ATL] Raising transformation errors and "auxiliary" parameters [message #66385 is a reply to message #66367] Mon, 19 November 2007 04:57 Go to previous message
--------------080003040008050109090701
Lorenzo Dalla Vecchia a
Previous Topic:[ATL] Problem with uml2copy.atl
Next Topic:How build DD Model with UML metamodel
Current Time: Fri Jul 18 03:26:22 EDT 2025
Powered by FUDForum. Page generated in 0.22844 seconds
